Old 01-06-2026, 04:56 PM   #1
ok1886
Drives: 2017 Subaru BRZ
Car can't start after parking overnight need help
Hi people. Have a big issue here
17 Stock BRZ, aftermarket intake and OFT Stage 1 map, catback exhaust, never touched engine.
HKS Spark plugs changed in 120,000km, now is at 160,000km.
Now living in Saskatchewan
Car failed to start after parking overnight, can crank, battery full charged doesn’t help.
First time happened back in October, pulled engine out and found cylinder flooded by gasoline, cleaned up and drives well.
Just happened again, same symptom, car can crank but not starting. Any idea?
No error code found either.
I’m doubting about sensors or fuel system issue.
MAF? MAP? Leaking fuel injector?
I attached YouTube video link down here, took some videos including trying start the car, trying flood cleaning mode and reading OBD data through OFT tablet.
Many thanks.
https://www.youtube.com/playlist?lis...zWSJMvt5oiSMVy
ok1886 is offline   Reply With Quote
Old 01-06-2026, 06:04 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If it's cold enough, your old battery on "full charge" really just may not be up to it. Is it the original? Do you have the original battery in it still?
Temp looked to read -18c.
I see fuel is full
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-06-2026, 07:48 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Nice videos. I would put the battery voltage on the OFT to monitor while it cranks.
Some of the attempts do sound like a weak battery, but that might have been due to you keeping cranking the car without it starting, as a few other attempts sound pretty healthy.
I would try booster cables or a booster pack to rule out the battery, other than that I can't help much.
Ohio Enthusiast is offline   Reply With Quote
Old 01-06-2026, 09:36 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Has you ruled out a spark issue? Spray a little starting fluid into the intake and see what happens.
Old 01-07-2026, 02:54 AM   #5
ok1886
Thank you for all replies, my original battery was done back in 2023, unfortunately the new AGM one was deeply discharged by the shop twice so it dies again after only two years, I bought a new battery today and now my car is back on road!
Old 01-07-2026, 02:55 AM   #6
ok1886
I see fuel is full
Thank you I bought a new battery to test today and I found the new battery from 2023 is done.
Old 01-07-2026, 02:56 AM   #7
ok1886
It is battery issue, I figured out today. Many thanks!
Old 01-07-2026, 03:02 AM   #8
ok1886
My car is back on road! It was battery issue, I didn't expect it dies in two years,
can't start, canada
saltywetman's overnight parts from japan NA build saltywetman Member's Car Journals 33 11-21-2021 01:36 PM
Has anyone flipped down their rear seats and slept in their car overnight on a road t jayhawkcole Scion FR-S / Toyota 86 GT86 General Forum 31 08-16-2017 04:59 PM
How can I keep tires warm while parked outside overnight? Pat Tracking / Autocross / HPDE / Drifting 14 04-25-2017 12:09 AM
Greddy Intake System / 5 in Stock / Free Overnight Shipping / Order Now!! rickspecd Engine, Exhaust, Bolt-Ons 11 07-12-2013 11:50 AM
My "First 86" FR-S Almost Stolen Overnight at Dealership hgamit Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2012 12:54 AM
