Old 12-20-2025, 06:55 PM   #1
jpeaslee
Drives: 02 Toyota 4Runner
SBD G500X rebuild, tuning problem?
I recently picked up a 13 BRZ from the guy that built it. Ran great, lots of fun. When I pulled the air filter off to clean it (K&N) I realized that the compressor blades were pretty chipped so I sent it off to BoostLab to have it rebuilt. Got everything back together today and seemed fairly uneventful. The linkage for the wastegate was a bit of a bear to get back on, but i got it.
Everything started up and ran fine. Took it for a test ride and all good until i hit 1psi on the boost gauge and the throttle completely cut out. Every time.
I thought maybe the wastegate linkage was too tight and adjusted it a hair, now it'll build to 2-3 and then it cuts out.
I have some tuning files if anyone has a better idea than me of what they're looking at and can point me in the right direction. I don't really know what I'm looking at, but when it's happening, the fuel injection PI ratio is cutting down to zero when it happens. It seems like it's the ecu cutting the throttle.
jpeaslee is offline   Reply With Quote
Old 12-20-2025, 07:16 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The waste gate should not be that tough to actuate, something is goofy. Pictures of it would be good!I'm betting the wastegate flap isn't fully seating or you have clamps that aren't tight.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Help: g500x Turbo BRZ - Tomei 80r vs Greddy RS. Which catback should i get rawr_brz BRZ First-Gen (2012+) — General Topics 1 07-18-2021 03:24 PM
SBD announces the new 54mm G500X Ball-Bearing Turbo Kit! spdbydesign Forced Induction 18 05-18-2021 05:15 PM
NEW for 2021: SBD G500X Ball-Bearing Turbo Kit: $2999 spdbydesignchris Forced Induction 2361 04-01-2021 06:53 PM
tuning problem mcnvgget Software Tuning 3 11-22-2019 08:21 PM
Nate's SBD/ZAGE Turbo Kit (DYNO Tune) by Bill@Delicious Tuning 2013GTRNate Forced Induction 38 05-29-2015 04:15 PM
