Old 11-20-2025, 08:53 AM   #1
BishamontenZC6
Drives: '14 BRZ Limited
Stripped undertray M8 bolt
One of the M8 front metal undertray bolts decided to give up after 100'000 miles on my '14. I don't know how it happened as I always torqued them properly. It's one of the 2 middle ones marked red at the bottom of that picture :
The thread in the hole apparently got stripped and the bolt is now spinning and impossible to torque down. This wouldn't be too much of a problem, but those are 2 of the bolts on wich my STI Flexible Draw Stiffener is attached, so I need to get them back in order.
I have a set of helicoils ready to be installed but I'm doubting about how much metal there is on the subframe to drill the holes up to 8.2mm in order to tap and install an M8 helicoil.
Did anyone ever try it, and do you think it will be ok ? Would there be any other solution ?
BishamontenZC6 is offline   Reply With Quote
Old 11-20-2025, 05:59 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The bolts circled in red just hold the fiberglass undertray to the steel undertray. It's just a nut clip (forgot the actual name lol) that slides over the fiberglass piece. The part where mine attached to disintegrated so I bought new clips and made a patch. I'm guessing that's what happened to yours.
The bolts in green are the only ones that are threaded into the chassis. I would be very surprised if one of those got messed up, I am sure I overtorqued them the last 30 times I've had to take that damn panel off.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
Wally86 (11-27-2025)
Old 11-20-2025, 06:04 PM   #3
Spuds
The Dictater
Spuds's Avatar
From post 154 of my build thread:
https://www.ft86club.com/forums/show...&postcount=154
I wound up having to redo it later with some fiberglass but that's actually holding up so far...
Old 11-21-2025, 03:18 AM   #4
BishamontenZC6
Yes sorry, I was in a hurry when I wrote the original post and mixed my colors.
I'm talking about the green circled M8 that holds the metal indertray, not the red small M6 holding the fiberglass. Those might hold more when they are only holding the undertray but the Flexible Draw Stiffener adds a quite a bit more load on them. The middle left one on mine is stripped. I also don't understand how it's possible as I probably removed and install them 100 times in the past 5 years.
The picture on your post gives a good view of the 2 holes that I need to helicoil.
The Following User Says Thank You to BishamontenZC6 For This Useful Post:
Spuds (11-21-2025)
Old 11-21-2025, 09:07 PM   #5
Spuds
The Dictater
Spuds's Avatar
I was thinking that brace would be installed wrong on the red bolts, but wasn't going to mention that yet lol.
Yeah I've got no idea how that happened to your car. Those are pretty beefy.
Good luck!
BishamontenZC6 (11-22-2025)
Old 11-22-2025, 09:27 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Look up an M8 Rivnut. Will probably be your best bet.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 11-22-2025, 11:48 AM   #7
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
It’s been some time since I worked down there but could you not drill and tap the stripped hole for a 9 or 10mm bolt?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Old 11-22-2025, 03:57 PM   #8
BishamontenZC6
Thank you very much for all your insights. I did the repair this morning and to my surprise it was much easier than I thought.
I drilled the existing hole at 8.3mm, tapped them with my helicoil kit’s M8 tap, installed the helicoil and everything is now solid and tight again. I’ve even been able to repair the thread on the OEM bolts, until I receive a full set of new ones.
After all the problems I’ve had on the car in the past 2 months, this came as a welcome surprise. I also figured out how the damage happened : the Flexible Draw Stiffener’s pressure flattened a section of the bolt’s thread, which isn’t a problem as long as it stays on (the brace is sandwiched between the subframe and the untertray). But as I’ve been chasing some really annoying suspension clunks since the past weeks, I removed the draw stiffener to see if it’s making the noises and when I reinstalled the undertray the bolts went deeper, which is when the damaged part of the bolt stripped the thread.
The Following 2 Users Say Thank You to BishamontenZC6 For This Useful Post:
Spuds (11-24-2025), Wally86 (11-27-2025)
Noise difference between seats down with stripped trunk vs stripped out back seats? StraightOuttaCanadaEh Cosmetic Modification (Interior/Exterior/Lighting) 11 10-31-2020 11:39 PM
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Stripped bolt head at over pipe/front pipe connection, what now? :( BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 43 01-14-2019 06:13 PM
Stripped Wheel Bolt Flame9020 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-09-2018 10:09 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 02:29 AM
