Drives: 2015 Scion FR-S
Stripped Wheel Bolt
I was changing my wheels the other day and noticed that all but one lug nut would torque to 100ft.lbs. The last would just spin and spin and spin so I think the bolt might be stripped. This happened with two other nuts I tried. I can crank it down until it tightens but then it's extremely hard to remove.
Questions are: 1. If the bolt is stripped where can I buy more/what part is it? 2. Are there bolts that are better/less prone to stripping than the stock bolts? |
Huge E85 fan!
Drives: 2016 Scion FRS
1) 100 ft-lbs is way beyond spec. 2) the damage was probably done by the last person to put the wheels on (cross threaded) 3) the lug nuts might have stretched threads and that's the issue with them not wanting to back off.
Country Boy 4 Life
I just replaced all of mine with a ball joint separator. It was fairly easy. i got extended ones, so dont have a part# for you.
I LIKE TIRES! |
Drives: 2014 Subaru BRZ
you can purchase a new stud from your dealer but they are prone to stripping
APR makes a more solid stud http://www.ft86speedfactory.com/arp-...l#.WqCM4WrwZhE |
| The Following User Says Thank You to VIP BRZ For This Useful Post: | Flame9020 (03-07-2018) |
Drives: frs
A pie-size of antiseize on threads for next time makes wonder too
| The Following User Says Thank You to Teseo For This Useful Post: | Erick KY (03-10-2018) |
1) Factory spec is around 89 ft-lbs.
2) You've likely stripped the stud if you can free spin and it's not getting any tighter. That's a more labor intensive job than simply finding a new lug nut. You're going to need a press to get that thing in. I would recommend upgraded studs like ARP.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Undisputed El Presidente
Drives: Zenki 37J ZN6
ARP studs require removal of the hub FYI. There is a DIY one the forum how to do it without a press, but a press is the correct way.
For now the OEM from the dealer is cheap and can be installed while it is still on the car (if in the rear you just need to rotate the hub around to get clearance to pull it out the back). Then use the washer method to install. And you might need a new lug nut while you are at it |
#9 | |
Country Boy 4 Life
A ball joint separator will easily remove and install the lug studs without removing the hub. A press is nice, but not necessary. I did all 20 of mine in an hour.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Tristor (04-18-2018) |
#10 |
You can install stock or extended in the front like that, but only stock length in the rear. To get the ARP studs in the rear you have to pull the hub out of the knuckle.
#12 | |
Country Boy 4 Life
I just took off the rear rotor to get to them. I installed extended studs. EDIT: I did not install ARP studs. If there is something different about them, I could be wrong about the process working with them. Mine are Ichiba +5mm rear studs that I installed with the ball joint tool. Additionally, there is zero way to mess up the threads using the ball joint separator to install over the "washer method".
I LIKE TIRES! Last edited by Leonardo; 03-08-2018 at 02:03 PM. |
#13 | |
ARP studs are about 2" longer then stock. They will not clear for the install without removing the hub in the rear What style ball joint tool did you use? I see 2-3 kinds when I google it and have only used a fork myself |
#14 | |
Country Boy 4 Life
via Imgflip Meme Generator[ame="https://www.youtube.com/watch?v=NEYz3Z8rHgo"]Lone Wolf Racing Honda S2000 Using a ball joint separator to remove wheel studs - YouTube[/ame] Press out the old, flip tool over, press in the new.
I LIKE TIRES! |
| How to remove seat rail bolt after you've stripped it | protpibe | DIY (Do-It-Yourself) Guides | 33 | 02-01-2020 02:06 PM |
| Stripped bolt head at over pipe/front pipe connection, what now? :( | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-14-2019 06:13 PM |
| HELP! Lug nut and wheel stud stripped! | jaydee_do_work | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 07-26-2015 01:50 PM |
| Wheel bolt stripped | 2pointSLOW86 | Issues | Warranty | Recalls / TSB | 23 | 10-13-2014 02:29 AM |
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 06:04 PM |
