Old 09-20-2025, 01:29 AM   #1
ImaginaryFriends
Drives: 2013 Scion FRS
EVAP purge solenoid routing?
Hi all,
I'm trying to put an EVAP purge solenoid back into my frs. I know one line routes to under the intake, where does the other one go? A picture would be helpful.
The line coming out of the intake manifold is currently used to run the BOV and boost gauge. Can I Tee off this to run it back to the EVAP solenoid?
If I'm missing something please lmk, thanks in advance!
ImaginaryFriends is offline   Reply With Quote
Old 09-20-2025, 07:21 AM   #2
whataboutbob
AutoX-10/10ths every run
There are 3 metal pipes on the driver's side related to fueling, one of them is for the evap return. The other two are fuel feeds, 1 goes to the port injectors, and one goes to the high pressure fuel pump. If your evap has been disconnected you should have the one for the evap return sitting there without a hose connected.
Build thread:Here
Bad ground at purge solenoid connection airrick Electronics | Audio | NAV | Infotainment 1 02-04-2021 09:14 PM
Evap Emissions Purge Flow CEL avishenoy1 Issues | Warranty | Recalls / TSB 5 05-01-2020 06:22 AM
EVAP/CPC Solenoid Delete? BRX Issues | Warranty | Recalls / TSB 7 09-09-2017 07:52 PM
Canister purge solenoid aero.kit Engine, Exhaust, Transmission 1 08-31-2014 02:19 PM
EVAP Solenoid Ryan P Forced Induction 0 06-25-2014 08:43 AM
