#1 | |
Drives: 01 911 Turbo, 03 G500
Surge Tank Mounting Location
For those that have sure tanks, where are you mounting them? It seems that trunk is popular but latest NASA rules seem to indicate that's not OK, specifically...
Drives: 2020 86 Hakone
If trunk mounted , the way I'm reading that, you would have to make a separate firewall to the rear.
| The Following User Says Thank You to downshiftxlr8 For This Useful Post: | smoltz (09-11-2025) |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I have a surge tank in two different FTs.
The "best" option is really dependent on your cage design or lack of. But you need to make a sheetmetal firewall. The issue is that the lines coming out of the OEM tank are RIGHT BEHIND the driver's seat. You need to see if the lines can be outside of the firewall and in the driver's compartment. If yes, you can mount the surge tank in the trunk and even just build a little box around it in the corner (behind rear wheel well?). If not, you could probably mount it right behind the gas tank cover thing behind the driver seat and then build a box around that whole setup. But it might be easier to just drop a sheet metal wall down from where the hatch is. We are using it for enduro, and have an aux tank. So we need both enclosed. We put it behind the driver rear tire well and then we made a firewall blocking off the entire trunk area.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
| The Following User Says Thank You to GrandSport For This Useful Post: | smoltz (09-11-2025) |
Car only has an autopower half cage now but is getting a full cage but still time to take this into account.
I am thinking of maybe removing evap canister and then putting surge tank there but tbh I've never had it all apart so maybe that's not realistic in terms of the size and location of these things. I had also been thinking of trying to just move to a fuel cell and copy the GR86 cup car setup but that doesn't appear NASA compliant which is a head scratcher as a "factory built" race car. |
| Radium surge tank | GrabTheWheel | Tracking / Autocross / HPDE / Drifting | 30 | 01-17-2022 08:35 AM |
| JUN GT SURGE TANK FOR FT86/BRZ | scubie.brz | Engine, Exhaust, Transmission | 60 | 11-23-2020 07:48 PM |
| Radium in-tank Hanger/ Surge Tank | DBlum425 | Engine, Exhaust, Bolt-Ons | 5 | 05-14-2020 12:05 AM |
| SARD Surge Tank Kit w/ ITB from TAS 2017 | mav1178 | Engine, Exhaust, Transmission | 50 | 05-12-2017 10:50 PM |
| Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion | Xero-Limit | Engine, Exhaust, Transmission | 42 | 04-27-2017 09:16 PM |
