Old 08-08-2025, 05:02 PM   #1
VR4Jr
Drives: 2015 BRZ Limited
17" width recommendation: 8.5" vs. 9"
I currently run a set of Wedssport 105N in 17x9 +35 with Michelin Pilot Sports 245/40/17. Car is stock in terms of power. Car is predominantly street with about one track event per year (HPDE).
I feel like it's slightly too much tire. It grips great, but the steering feels a little number and less "on rails". I'm not concerned about lap times and more concerned with overall feel and driving experience, so I'm considering a slightly smaller wheel and tire.
Wedssport makes the 105X, successor to the 105N, in 17x8.5. So I'm thinking to move down just a bit to that coupled with 235 tires.
Thoughts? If that's the right wheel/tire mix, what offset do folks suggest in 8.5?
I realize these are minor changes and a nice "problem" to have.
VR4Jr is offline   Reply With Quote
Old 08-08-2025, 05:29 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
235 tires are fine on 9" wheels. If you think you might even want to go down to 225, 8.5" would be better. Otherwise you'd actually gain a bit more feel from the extra stretch of 235 on 9" wheels.
I'd try 235 tires on your current wheels before spending money on new wheels.
I'm running 17x9 +35 with 235/40R17 tires as my track set, but also ran them on the street for a bit and it was great.
Ohio Enthusiast is offline   Reply With Quote
Old 08-08-2025, 06:49 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Agree a 225/45 will give you more of what you want. A 8.5 can work with 225 though it'll look a bit more stretched.
Old 08-10-2025, 07:46 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Try 235 or 225 on your 9" wheels.
Which Pilot Sprt tires are you on, there's like a gazillion different ones! Tire choice will be more important for steering feel than wheel/tire sizes...
Old 08-21-2025, 07:05 PM   #5
bhmax
Drives: 13 BRZ, 17 Focus RS
What’s your alignment settings? Could be more important than the wheel and tire changes you’re looking to make.
bhmax is offline   Reply With Quote
Tire rack test on tire width vs wheel width nissanfanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-08-2023 03:05 PM
The Different between "Gain Grip by Width" & "Gain Grip by Compound"? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 05-03-2014 02:26 AM
Stock width, stock "feel" bigger rim? Trashed675 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-12-2013 12:39 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
