Old 07-24-2025, 06:07 PM   #1
Koba
Drives: 2020 BRZ
Reverse light to rain light?
Is there an aftermarket company that sells a reverse light that acts as a rain light for race application?
I looked around and only found some places that convert it into a brake light.
Hopefully plug and play with an ON/OFF switch.
Koba is offline   Reply With Quote
Old 07-25-2025, 11:10 AM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
At least on my 2016, if you look under you will see that a spot is molded into the lower light for bulb installation however it’s not open. I drilled/dremelled it out and installed a bulb socket and led bulb from a local auto parts store.
Mine is wired to a brake flasher module but you could easily wire it to a switch and a 12v source. Or wire it to the taillights with a switch in the tire well as you’ll likely be using full lighting at the same time.
Good luck.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-25-2025, 01:29 PM   #3
Koba
Drives: 2020 BRZ
Thanks!
Never really looked under there, if nothing is available off the shelf I am sure I can Macgyver something.
On a different note... do you do any track days at Mosport, would love to take a look at your car, thinking of boosting it too.
Old 07-26-2025, 02:26 PM   #4
Muskoka800
We track at TMP and Grand Bend since moving to Chatham from Burlington. My Burlington Bud has a 2010 Miata. We haven’t been out yet this season. He has a new job and I had hand surgery in April which has me still on the mend.
Do you have VALENTI Reverse Bar + Reverse cam? *SOLVED tiz22 Electronics | Audio | NAV | Infotainment 16 07-18-2017 12:36 PM
2013 BRZ Reverse Light (Reverse & Reflector) kberkel Exterior Parts (Aero, Lighting, Etc.) 0 08-14-2016 01:14 AM
Rain rain rain! Phantobe Southern California 9 12-15-2015 01:28 AM
Debate: Reverse in or reverse out. paulca Other Vehicles & General Automotive Discussions 31 07-21-2014 09:56 PM
Rain, rain go away! Partial Stall New England 26 06-05-2012 06:55 PM
