Drives: 2025 BRZ, ex-2012 GT86
RCE SS2 Coilovers + Verus LCA + Other stuff?
Just picked up a 2025 BRZ – completely stock for now apart from a COBB titanium catback. It came with factory Brembos, so no aftermarket BBK needed.
Backstory: I used to own a JDL-turbo GT86 with built engine and all possible mods including carbon driveshaft, crazy clutch, all possible suspension bits etc. Before that, I ran through two HKS V2 superchargers – both failed quickly and soured me on HKS permanently. With this Gen 2 BRZ, I’m so far committed to keeping it naturally aspirated and more balanced overall. No mods for the sake of modding (I will try my best this time )Next steps: wheels + suspension. Wheels/Tires Planning to go with: • TWS T66-F 18x8.5 ET42 • 245/35 tires – leaning toward Cup 2, AD09, or R888 I liked very much in the old car (yes, I know it’s overkill for NA – will post a separate thread in the wheels/tires section for more input there). Suspension Setup Main goal is track capability with decent street manners. My tentative setup: RCE SuperStreet 2 coilovers https://www.racecompengineering.com/...-2022-brz-gr86 Verus 7000-series rear LCAs https://www.verus-engineering.com/sh...46#attr=190,17 To help dial in ~2.5° rear camber and prevent any fitment issues. RCE sway bars (20mm front / 16mm rear) https://www.racecompengineering.com/...-brz-fr-s-gr86 RCE end links https://www.racecompengineering.com/...-brz-fr-s-gr86 Learned my lesson trying to pair Ohlins with Whiteline sway-bars on my GT86 – thick Whileline ones didn’t work, ended up with Hotchkis and still had to trim them a bit and add additional threads. Since I’m based in Dubai, I’m trying to order everything in one go to save on shipping and install time - thus RCE sways and end links but happy to switch to other brands if there is a good reason for that. Looking for constructive feedback or alternate suggestions. Would you change anything in this setup? Any red flags? Especially curious if anyone has long-term experience with any of the above mentioned parts on a track-driven Gen 2. Last edited by Efferalgan; 07-05-2025 at 06:37 PM. |
| The Following 2 Users Say Thank You to Efferalgan For This Useful Post: | autoracer86 (07-06-2025), SuperTom (07-06-2025) |
Drives: Toyota GT86
Looks like a great setup.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Efferalgan (07-06-2025), SuperTom (07-06-2025) |
Adjustable endlinks, shorter in the back, they are really needed on the back in particular.
AutoX-10/10ths every run
I'd get the SPL Rear LCAs for the additional adjust-ability.
| The Following User Says Thank You to whataboutbob For This Useful Post: | Efferalgan (07-06-2025) |
The shortest you can find, because the rear ARB is not parallel to the ground. Some relocation brackets help too.
You can even remove pre load, much needed. I'm using Revolution end links at the back. |
| The Following User Says Thank You to gpvecchi For This Useful Post: | Efferalgan (07-07-2025) |
#7 | ||
Drives: '23 BRZ
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | Efferalgan (07-07-2025), Racecomp Engineering (07-07-2025) |
#8 | |
A052s are an option too. Can you post a pic how they look on 9”? In recent TireRack test 225s on 9’” surprisingly showed best times (better than 245s on 9”) and also very positive reviews on their manners There is no wet in Dubai only hot&dry and very hot&humid
| The Following 2 Users Say Thank You to Efferalgan For This Useful Post: | Racecomp Engineering (07-07-2025), ZDan (07-07-2025) |
I think the 245 makes sense for higher track temps in Dubai! The 225 maybe a little bit faster in good conditions for a few laps but for longer sessions I'd want a 245.
We are working on rear endlinks but it will be a little while. The SPL will do well in the rear. Good list and we'll be happy to support as best we can. ![]() - Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | Efferalgan (07-08-2025), ZDan (07-09-2025) |
#10 | |
Drives: '23 BRZ
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#11 |
225?
Looks quite all right. On 8.5” A052S should look totally fine - I checked, they run really wide. Thanks a lot for the pics! 225/40 A052S on 8.5 is my first choice now.
| The Following User Says Thank You to Efferalgan For This Useful Post: | ZDan (07-09-2025) |
| Racecomp Engineering Superstreet 2 coilovers available now (RCE SS2) | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 07-12-2024 06:25 PM |
| RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 589 | 11-21-2021 05:13 PM |
| FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 236 | 06-20-2019 02:42 PM |
| EBC yellow stuff/red stuff | R3AP3R_Playz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 09-13-2016 06:37 PM |
| CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff | CruiseControl | Member's Car Journals | 4 | 07-01-2014 06:53 PM |
