Old 06-25-2025, 09:33 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Accusump oil level?
Successfully installed Accusump, thanks Ansix Auto!
I may have overfilled though, I'm seeing +1/4 quart overfill at 100psi and +1.25 qt overfilled at 20psi! OK to track or not? Kind of assuming that any overfill will be dealt with by PVC but let me know if I need to take oil out before tracking at Mosport in a few days.
Thanks!
smoltz (06-25-2025)
Old 06-25-2025, 09:31 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Have you looked up Boyles Law yet? I found it helpful to calculate the amount of oil in the accumulator at a given pressure.
I'm not a fan of the electronic switches. When deactivated, they still allow oil flow into the accumulator. On a cold start with 100+ psi you push a lot of oil into the accumulator. Also, they are slow to react to a drop in OP. From what I have seen, the drop in OP is momentary. By the time the switch would activate, the pressure is already coming back up.
I use a manual valve with a PTO cable. When the engine is warm, I open the valve, hold rpms so the OP is around 70 psi and then close the valve. I then top off the oil in the engine.
Old 06-27-2025, 02:37 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Linear relationship, so lower initial charge pressure = greater oil volume into Accusump.
I have the electric valve but not using a pressure switch, I just have an on/off switch in the cockpit. On the street, I open the valve to pre-oil before starting and leave it open until the oil warms up, the close it at ~4000-5000rpm to have a decent pre-charge for next startup. At the track I will leave the valve open for a stint, then close it on the cool-down lap or in the pits, again at ~5000rpm for pre-oiling.
OK, we are doing the same thing. I intended to have it a little bit over-filled at 60ish psi but I unintentionally overfilled a bit more then I meant to...
Old 06-27-2025, 05:40 AM   #4
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
What sort of changes are you seeing to oil pressure when doing this ? Does the accusump eliminate oil pressure loss in corners or just helps for quicker recovery.
Thanks
autoracer86 is offline   Reply With Quote
Old 06-27-2025, 12:35 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks
Only just installed it, and stupidly enough I have no way of measuring pressure (should have installed pressure sensor in the electric valve...).
First track days with it Monday/Tuesday.
I am 100% relying on the testing of others on this. Ansix Auto (great deal on the whole kit btw), 900BRZ, BTR Justin, etc. There's lot's of great test info out there.
From everything I can tell, the Accusump greatly reduces pressure drops and recovers from them sooner.
From Ansix:
Old 06-27-2025, 01:45 PM   #6
blsfrs
blsfrs's Avatar
Correct me if I am wrong, (my wife does it all the time) but the electronic valves allow the accumulator to fill with oil even when "off".. Yes? It makes it harder to get to correct oil level in the engine.
Years ago, I graphed pressure vs volume. It seems to follow a slope not a straight line.
Old 06-27-2025, 03:22 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should be a linear slope, no?
Yeah I have a hard time reading oil levels anyway, one side of dipstick says full, other side says 1/2-qt overfilled…
Old 06-28-2025, 10:27 AM   #8
blsfrs
blsfrs's Avatar
Sorry, my last trig class was many moons ago so my grasp of terminology is foggy at best. If you plot the volume v pressure the line is curved not straight. Parabolic might be what I'm trying to describe.
The Following User Says Thank You to blsfrs For This Useful Post:
ZDan (06-28-2025)
Old 06-29-2025, 06:57 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
P1V1 *should* = P2V2. I doubt the dipstick scale is linear...
blsfrs (06-29-2025)
Old 07-01-2025, 10:09 AM   #10
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Right?!?
Is there a consensus on this? Average out the 2 sides? Always go by the lower? The higher? Keep adding till it comes out the breather?
smackrel is offline   Reply With Quote
Old 07-01-2025, 01:10 PM   #11
blsfrs
blsfrs's Avatar
Originally Posted by smackrel View Post
Right?!?
Never check you oil when there's a full moon. The tidal forces pull the oil to one side of the pan.
T-Steve (07-04-2025)
Old 07-01-2025, 02:52 PM   #12
smackrel
Full Throttle!
Makes sense. Ill make sure to check my Lunar calendar before I schedule a oil check next time.
The Following User Says Thank You to smackrel For This Useful Post:
blsfrs (07-01-2025)
Old 07-03-2025, 09:31 PM   #13
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Thanks!
What PSI does it open at?
Of course it's going to be high at low pressures- the accusump is pumping in oil!
Prior to accusump we ran with about a quart over full and it was fine.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 07-04-2025, 02:17 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
I am running it on track with the electronic valve open all the time. For "normal" usage, I'll open the valve before startup, then close it after it has warmed up a bit.
Ansix Auto's Accusump Back to Back Track Testing Ansix Auto BRZ Second-Gen (2022+) — General Topics 1 10-14-2023 10:41 AM
Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results Ansix Auto GR86 General Topics (2nd Gen 2022+ Toyota 86) 49 09-14-2023 08:35 PM
2qt Accusump, -10 AN line, fittings, bracket, remote operating cable Joesurf79 Engine, Exhaust, Bolt-Ons 29 02-24-2023 01:04 PM
Accusump install LS1M Engine, Exhaust, Transmission 62 10-11-2018 11:21 AM
Accusump Operation wizzo Engine, Exhaust, Transmission 15 03-24-2016 05:20 PM
