Old 06-23-2025, 01:43 PM   #1
FastLap
Drives: 2025 Toyota GR86 Premium PP
Question Will these lug nuts work with the stock wheels?
I’m considering picking up a set of these so I can use them both with my Autocross wheels and the stock wheels. Anybody using these with stock wheels? Just want to make sure the conical seat is correct as I keep seeing regular cones and “bulge” type. Not sure if both are compatible or not.
https://www.jegs.com/i/Gorilla-Autom...BC-20/10002/-1
FastLap is offline   Reply With Quote
Old 06-23-2025, 03:18 PM   #2
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I use them on my track/autox wheels but I also have 3-1/4" ARP wheel studs.
They stick out like crazy on the stock wheels.
RT-BRZ is offline   Reply With Quote
Old 06-23-2025, 03:33 PM   #3
FastLap
Thanks. Are your track wheels a different offset? Seems like they would stick out the same amount on either set. I’m planning to run spacers on my track wheels so the offset change will be behind the wheel and the lug nuts should stick out the same with or without the spacer (as I plan to take the spacer off for the street wheels).
Old 06-23-2025, 03:55 PM   #4
RT-BRZ
RT-BRZ's Avatar
My track wheels are 17x9 +35. They do also stick out a bit but since the studs do that already, it's not too obtrusive. On the OEM wheels, it's a good bit more obvious.
Old 06-23-2025, 05:08 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Gotta ask, what do you think these lugs will do for you that the stock ones don't?
Old 06-23-2025, 10:51 PM   #6
FastLap
The stock lug nuts will bottom out with longer studs.
[SoCal] FS: Rays Dura Nuts Lug Nuts 12x1.25 scotterson Wheels and Tires 8 12-17-2020 02:33 PM
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 09:47 PM
Wrx lug nuts and frs lug nuts? Frs123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-15-2013 08:35 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
Subie Lug Nuts on Work wheels? Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-20-2013 05:50 PM
