Old 06-09-2025, 08:25 PM   #1
warhawk03
Drives: 2018 BRZ
Endlinks wore down paint on chassis, what's the fix?
I installed some Whiteline Endlinks along with a Whiteline Front Sway Bar. Before my alignment, the endlinks made some contact on the inner firewall/chassis and wore the material down to bare metal. I'd like to clean it up. What did Subaru use to coat the chassis inside the wheel well?
warhawk03 is offline   Reply With Quote
Old 06-10-2025, 04:19 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s just standard automotive undercoating.
Old 06-15-2025, 05:21 AM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I just use primer from a spray can. They sell undercoat in cans too.
I tend to spray it into paper bowl or something and brush it on because I prefer not to overspray everything in the vicinity.
EndlessAzure is offline   Reply With Quote
Old 06-15-2025, 01:52 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Metal prep like rust converter then rust paint or something thick.
Primer in it self is porous, would definitely be spraying something on-top to seal it.
Old 06-15-2025, 08:03 PM   #5
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
If it's worn down to the metal and not rusting, usually just touch up paint works. If it's surface rusted, sand it down to bare metal, possibly use some rust converter/prep, then paint.
If you're really OCD about it like me, do the touch up and Fluid Film everything. As in the entire car, even if it's a spring/summer/fall only car. I had the same thing happen and because it had Fluid Film all around it, it coated it without me even knowing after it happened and prevented any rust from forming.
cmiovino is offline   Reply With Quote
Old 06-19-2025, 02:20 AM   #6
EndlessAzure
Wheels for Brains
Not too worried, as long as it's not polyester-based primer
New Nameless Muffled Track pipe, Perrin Lock down, Whiteline rear endlinks. dreamwonder Brakes, Suspension, Chassis 9 05-11-2020 06:23 PM
Ferodo DS2500 pads wore out very quickly MassTroy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-03-2017 12:34 AM
Is your Injen intake gettin' ya down? Here's how ya fix it. ML Engine, Exhaust, Transmission 60 01-12-2015 01:50 PM
There is a new window switch available to fix the passenger auto up/down issue Subie Issues | Warranty | Recalls / TSB 51 04-13-2014 02:34 PM
Help! Trim clips lost down inside chassis! GTS 86 DIY (Do-It-Yourself) Guides 3 08-26-2013 10:50 PM
