Old 04-12-2013, 10:12 AM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Is your Injen intake gettin' ya down? Here's how ya fix it.
That's right folks. I was having a bad experience with my Injen intake, so I went down to my local auto shop, purchased some 3 1/2" pipe and fixed that shit. More specifically stopped the acceleration lag/bogging. Throttle response now feels like stock with the extra *umph* that the larger air flow provides. If I hadn't gotten the intake cheap, and the pipe cheap, this would have been a cash boat in its self.
Only problems I have come across are if you idle for about a minute or two the heat will build up and RPMs will drop ever so slightly, but never has it stalled. NO CELs thanks to the Unichip.
PS. yes I painted all the yellow shit in the engine bay.
The Following User Says Thank You to ML For This Useful Post:
LeeMaster (04-12-2013)
Old 04-12-2013, 10:14 AM   #2
2forme
Did you remove the plastic shroud that normally sits on top of the radiator?
Old 04-12-2013, 10:25 AM   #3
ML
ML's Avatar
Yes I did. Or are you talking about the foam that goes above the rad?
Old 04-12-2013, 10:27 AM   #4
FR-S Matt
So you basically turned it into one of the true cold air intakes? Not bad for a DIY at all. Glad it worked for you. Everyone is starting to understand that the best CAI's pull from the bumper.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ML (04-12-2013)
Old 04-12-2013, 10:33 AM   #5
2forme
I think it looks much better, too.
The Following User Says Thank You to 2forme For This Useful Post:
ML (04-12-2013)
Old 04-12-2013, 10:36 AM   #6
tennisfreak
Drives: 2018 BMW M240i
Wow that thing looking f_cking ginormous!!
The Following User Says Thank You to tennisfreak For This Useful Post:
ML (04-12-2013)
Old 04-12-2013, 11:55 AM   #7
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Nice, I was thinking of doing this myself after the Oil cooler lines rendered my Injen intake useless.
Can you take a closer picture of the radiator area where the snorkel tube ends? When I look at mine it dont look like there is a lot of space to fit a 3 1/2 tube in there, but it look like it worked for you.
Also, it looked like you purchased two 90 degree tube, and one straight tube?
Also, any noticeable difference in sound? cold air cai
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
ML (04-12-2013)
Old 04-12-2013, 12:08 PM   #8
ML
ML's Avatar
AHHHH you caught me. That was the tricky part of this install. The area you are referring to I really had to think about what to do. Indeed the 3 1/2 chrome pipe WILL NOT fit under the white cross member, so what I did was took a 3 1/2 piece of plastic tube and cut it to about 2 inches long. Then I stuck two rubber connectors on it so that they fit end to end. Then I connected the two 90 degree tubes with this long rubber/plastic piece. You see the white cross member piece un bolts and is a very thin piece of stamped steel. It seems its only purpose is to hold the hood latch, and hold the bumper on. So when I got my piping done and I put the cross member back on the rubber/plastic piece was able to flex under the cross member, and be a little elliptical. So yeah it was tricky.
Old 04-12-2013, 01:19 PM   #9
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Awesome! Too bad I sold mine now, haha. And... Isn't that red, not yellow shit in the engine bay? One of us is color blind. lol
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
The Following User Says Thank You to BuBlake For This Useful Post:
enjoi23 (06-09-2013)
Old 04-12-2013, 01:23 PM   #10
SkullWorks
Drives: SSM LT MT BRZ
...I think he means he painted all the stuff in the engine bay that came yellow stock...as well as some other stuff obviously...
SkullWorks is offline   Reply With Quote
Old 04-12-2013, 01:23 PM   #11
ML
ML's Avatar
I mean, I painted all the yellow to red
Old 04-12-2013, 01:51 PM   #12
BuBlake
BuBlake's Avatar
Oh. Thanks for clarifying. I'm assuming that you just kept the Injen map with Unichip? Might give the Perrin one a shot as it's more like your setup now.
Old 05-13-2013, 03:40 PM   #13
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
@ML
What did you use for your MAF/Vacuum line?
Trashed675 is offline   Reply With Quote
Old 05-13-2013, 06:01 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Trashed675 View Post
@ML
The original positions on the Injen pipe I'd assume.
.: Stealth 86 :.
Kodename 47 DJ:
WTB: Injen intake Obja Engine, Exhaust, Bolt-Ons 3 01-10-2014 10:20 PM
Injen Intake seven Engine, Exhaust, Bolt-Ons 4 03-09-2013 02:40 AM
Does anyone in NE have an Injen intake 2forme New England 2 10-28-2012 06:22 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
