Old 06-09-2025, 07:54 PM   #1
Ben_Motorsport
Drives: Suabru
Need Help with Remote Programming
Hello
I want to see if anyone can help me to re-program the ECU remotely to make it back to Stock ? Trying to pass smog in California and it showing software is modified. Car is 2016 Scion FR-S
Ben_Motorsport is offline   Reply With Quote
Old 10-09-2025, 12:53 PM   #2
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Which tune system is car programmed with
If it's ecutek even writing back a stock tune won't pass in California due the embedded ecutek licience you need to delete the locience as well so the checksum is correct for smog
AussieBRZ is offline   Reply With Quote
Old 10-10-2025, 01:39 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
FWIW: Swapping out the ecu is not that complicated. Used ones are around $100. If you do go that route, make sure the vendor/junkyard has the underdash ecu and doesn't try to send you the DI driver.
Need Help with Remote Programming Ben_Motorsport Scion FR-S / Toyota 86 GT86 General Forum 1 09-06-2025 07:44 PM
Need help with Ecutek programming and data logging stlgrym3 Southern California 0 08-10-2018 01:58 PM
Remote won't unlock doors. Need help diagnosing problem. DeviantBlue Issues | Warranty | Recalls / TSB 21 06-05-2018 02:23 AM
Ecutek help: unable to choose rom file in Programming Tools software Fizz Software Tuning 7 12-18-2014 03:30 AM
Help with School Assignment.(Programming with Python) Zaku Off-Topic Lounge [WARNING: NO POLITICS] 0 04-09-2013 02:55 PM
