Old 06-06-2025, 11:11 AM   #1
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Question Clutch Spring removal help?
I read thru the entire How To thread:
https://www.ft86club.com/forums/showthread.php?t=103157
Lots of people saying it was an easy mod, so I ordered the GK Tech springs.
https://us.gktech.com/products/gt86-...b3bd9a9f&_ss=c
Got under there to swap it out and was unable to even remove the eclip. Lots of peoples saying it was sooooo easy on the how to thread, hell one guy even did on his lunch break at work with no tools....
To them I ask, what am I missing? I had my steering wheel off since I was swapping it out and still couldn't situated in a way that offered me access enough to really manipulate anything in there. I'm considering removing the wheel AND the seat next time I try to help me be a little more comfortable while I contemplate my existence.
I'm not huge, 6'2'' 220 mostly legs, but damn if I felt like I was all thumbs under there. I know it sounds like it, but I am not a dumbass. I do almost all my own maintenance and mods. Plz tell me your secrets. Is it laying a certain way? going in arms first? Are all of you double jointed? plz help
smackrel is offline   Reply With Quote
Old 06-06-2025, 01:13 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I would guess your size is working against you. I'm 5'10 and my back is on the SIL when ever I'm doing anything under there. Very cramped. I make old man noises when I need to stand back up again.
If I recall I used pliers to get the clevis pin off, but it's been a solid 7 years since I did that mod.
Old 06-07-2025, 02:35 PM   #3
2.2Lude
2.2Lude's Avatar
I'm much shorter at 5'6" 170llbs but really had no trouble with this. You can try depressing the pedal a little which should take some tension off and make it easier to pull everything off. If space is the limiting factor then removing the driver seat will certainly give you a lot more room to work with. Just be careful with those stupid pre face lift seat mounting bolts.
2.2Lude is offline   Reply With Quote
Old 06-07-2025, 11:00 PM   #4
Eaton PSI
Drives: 2013 86
Is your car left or right side drive? Mine is right side and getting the spring out was brutal. There is no way I would have attempted to refit it. I waited a while to make sure I liked how it drives without it (which I do) then I threw the spring and other parts away.
There is a video in another thread where the guy removes the whole pedal and does the mod on the bench. This might be easier.
2014 GT86, 2.2L big bore, harrop supercharged
Eaton PSI is offline   Reply With Quote
Old 06-10-2025, 10:48 AM   #5
smackrel
Full Throttle!
My car is a 17 so I don't think I have the stupid bolts. I did remove the seats to do a carpet cleaning after buying the car used recently. Read online that you need a Torx bit to remove and bought a kit. Went to go take my seats out on cleaning day and all the seat bolts are just that... regular bolts. Go figure lol
OT Re you username: One of my many Hondas was a BB6. Man I loved that car! So smooth, but still hauled ass! Still miss it
Old 06-10-2025, 10:52 AM   #6
smackrel
Full Throttle!
Mine is LHD. I guess I should be thankful I have it "easy"
I saw a pic of the RHD pedal assembly and there's no way I would have even attempted that lol
I reread the thread and someone mentioned bumping the EClip while in place. Ill try that next time and if that doesn't work I will consider removing the assembly.
Thanks to both you for your responses and suggestions!
Old 06-14-2025, 06:56 AM   #7
Eaton PSI
Drives: 2013 86
If you do this mod, take it for a drive with no spring before you fit the GK Tech spring. The spring is totally unnecessary and you may find you're happy without it.
Old 06-14-2025, 07:41 PM   #8
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've been springless for years.
Old 06-15-2025, 09:22 PM   #9
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Also if you do this mod, put a towel down all over the carpet and as far back and up as you can. Might even want to order a new $5 pin just in case. Mine went flying when I popped it out, even with a small towel down and got lodged behind the carpet somewhere. Went looking for it to no avail. Put another pin-type thing in there temporarily until the new correct part one came in a few days later.
Personally, I liked the MTEC spring I was installing rather than springless. Mine was also a 2017.
cmiovino is offline   Reply With Quote
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans! VerusEric DIY (Do-It-Yourself) Guides 242 05-21-2025 08:05 AM
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
