Old 06-03-2025, 11:15 AM   #1
smoltz
Drives: 01 911 Turbo, 03 G500
Radium Fuel Basket vs Verus Fuel Flap
Does anyone have any experience with both?
Thoughts?
I beleive I am having fuel starvation issues (Stock NA FA20) on track. I will likely just use the Verus flapper door to start, but would consider the radium fuel basket.
smoltz is offline   Reply With Quote
Old 06-03-2025, 11:46 AM   #2
M0nk3y
Radium fuel basket is a slightly larger area within the pump and still relies on a 1-way check valve to fill the basket, but either system will still encounter fuel starve issues depending on slosh.
The positive aspect of the Radium offering is it can take a return line from a return-type fuel system to fill the basket as priority, so unless you're going with a surge tank offering IMO it would work better than the Verus Flapper, but you'll still run into issues.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
smoltz (06-03-2025)
Old 06-03-2025, 01:26 PM   #3
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I had predictable fuel starve situations at certain tracks/corners once I was e85, aero, sometimes hoosiers. The typical problem. I found the Verus flap did help but was still overcome at times. My solution was adding a submerged low pressure pump to the right side of tank with hose feeding the primary pump basket. This has completly solved the problem for me. No issues running level down to 1/8th. I think I spent $50 or so.
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
The Following 3 Users Say Thank You to bmacfrs For This Useful Post:
NoHaveMSG (06-08-2025), smoltz (06-03-2025), whataboutbob (06-04-2025)
Old 06-03-2025, 03:52 PM   #4
M0nk3y
I think the one benefit to the Radium tank would also greatly become more beneficial when used with a lower pressure pump, since it would input directly into the 1-way check valve fill basket
Kyle H. - #89 STX
bmacfrs (06-03-2025)
Old 06-06-2025, 02:07 PM   #5
fminicooper
Drives: FRS Hot Lava
I've been using the Verus Fuel Flap for quite some time, and it completely solved my fuel starvation issues—it's been working like a charm. My FRS is a naturally aspirated stock setup with no aero, prepped for the track and running on 200TW tires.
fminicooper is offline   Reply With Quote
The Following 3 Users Say Thank You to fminicooper For This Useful Post:
2.2Lude (06-07-2025), RT-BRZ (06-06-2025), smoltz (06-06-2025)
Old 06-06-2025, 05:28 PM   #6
smoltz
Verus Flap Ordered -- Once installed I'll report back
Old 06-06-2025, 07:05 PM   #7
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I went with the GKTech flapper on mine and so far I have nothing negative to report.
I had a BF deal and I was boosting my car so I had a "save every penny" thing going on in my head. I like Verus stuff and have a good bit on my car but my cheapskate nerve kicks in every now and again.
RT-BRZ is offline   Reply With Quote
Old 06-08-2025, 01:37 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you powering that separately or tied into the OE fuel pump power connection?
Old 06-08-2025, 03:01 PM   #9
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
On its own fused relay with a dash switch so it not constantly pushing fuel to the drivers side. You have to run wires thru the top of the sender cover anyway
Sent from my SM-S901U using Tapatalk
The Following User Says Thank You to bmacfrs For This Useful Post:
Old 06-08-2025, 04:19 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Kinda the direction I was going to take. I didn’t know if the stock fuel pump controller could handle two pumps at once. I was going to run dash switch with relay to a small PWM motor controller since I don’t think I will need full beans on the secondary pump to keep it from starving.
Old 06-08-2025, 08:19 PM   #11
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
That should do it
FS: DW300c Fuel Pump w/ Fuel Basket Irace86.2.0 Engine, Exhaust, Bolt-Ons 1 10-05-2023 11:26 PM
Using roof basket 101? lapsio Other Vehicles & General Automotive Discussions 2 06-08-2023 09:33 PM
Fuel starvation, verus flap? ZDan Tracking / Autocross / HPDE / Drifting 9 05-19-2021 12:47 PM
Sealing a return line fitting, through a hole in the top of the fuel pump basket? Joesurf79 Engine, Exhaust, Transmission 2 11-12-2018 08:17 PM
Full Blown Motorsports Walbro 485 Kit installed in Basket + more OmarGC Engine, Exhaust, Bolt-Ons 3 05-06-2017 10:29 PM
