Old 04-30-2017, 10:26 AM   #1
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Full Blown Motorsports Walbro 485 Kit installed in Basket + more
I've upgraded my fuel system, so I no longer need this setup. It has worked flawlessly for the past 3500 miles controlled via my standalone ecu.
$250 + ship
What you get:
Everything you would get if you ordered the FBM 485 Kit (Pump, billet ring/o-ring, billet pump holder, 1:1 reg, etc.)
OEM fuel basket with fbm 1:1 regulator installed, hanger modified for return line(-6), quick release to -8 fitting, -8 adapter fitting.
It is setup for return line so if you dont have a return line setup, simply cap the -6 return fitting. Also, if you have stock fuel feed lines you can remove the quick disconnect fitting and your stock line will connect as normal.
* you will need to transfer your rubber hanger/tank seal, fuel level sensor(single release tab), and plastic venturi line lock.
** recommend buying a new fuel sock, just because it's right there/easy to do.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
Old 04-30-2017, 07:11 PM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Updated
Omar GC
Instagram: 2jzus
OmarGC is offline
Old 05-03-2017, 01:02 AM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Bump
Omar GC
Instagram: 2jzus
OmarGC is offline
Old 05-06-2017, 10:29 PM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Sold
Omar GC
Instagram: 2jzus
OmarGC is offline
WTB : Full Blown FRS/BRZ Walbro 485 Fuel Pump Kit SmsAlSuwaidi Want-To-Buy Requests 2 04-10-2015 10:52 PM
Fs: Full Blown Motorsports oil cooler protpibe Engine, Exhaust, Bolt-Ons 1 03-25-2015 06:36 PM
Results after full blown kit installed frs87 Forced Induction 86 04-10-2014 04:37 PM
Full Blown Motorsports Vs Beatrush catch can JordanWho Engine, Exhaust, Transmission 20 02-13-2014 11:08 AM
Full Blown Motorsports Base Turbo Kit with e85 Upgrade TyperRspec789 Engine, Exhaust, Bolt-Ons 24 07-12-2013 04:58 PM
