Old 05-15-2025, 12:18 AM   #1
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
Track day oil change intervals for my 2017 BRZ
Hello everyone, I have two questions I'd like to ask.
I've stockpiled a lot of ACEA C3 spec motor oils, including Shell ECT 0w30 and Mobil 1 ESP 0w30. These oils also carry VW50400, MB229.52, and Porsche C30 certifications. At the race track I frequently visit, I can run 12 sessions in a day, each lasting 20 minutes. My 2017 BRZ is mostly stock, with only modifications to the tires, oil cooler, brake discs, and brake pads. At my current level of track driving, the oil temperature generally stays below 115°C.
My first question is, given these conditions, how often should I change my oil? Should I change it after every track day (12 sessions)?
My second question is, I also have plenty of A3/B4 spec oils, including Total Energy 0w30 and Castrol Edge 0w30. Would using these oils be relatively better? Could they potentially extend the oil change interval?
Thank you everyone.
qiumaoyuan is offline   Reply With Quote
Old 05-15-2025, 02:49 AM   #2
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Your best bet is to do 2 track days then get the oil analyzed and see how it’s holding up.
I change my mobil 1 super 3000 xe1 5w30 after 3 or 4 days. Oil temps are normally hitting 120c highest I ever seen on track was 123c.
Like I said best to get it analyzed instead of just guessing. If you want to play it safe change after 2 track events.
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
qiumaoyuan (05-16-2025)
Old 05-16-2025, 03:14 AM   #3
qiumaoyuan
qiumaoyuan's Avatar
Alright, thanks. I'll send the used oil for analyzing. I'm just concerned about whether it will hold up through the second track day.
The Following User Says Thank You to qiumaoyuan For This Useful Post:
autoracer86 (05-16-2025)
Old 05-16-2025, 08:18 AM   #4
autoracer86
Drives: Toyota GT86
Well nothing wrong with sending the oil after 1 track day to see how it’s done. Then send another sample of say 3 track days. It’s a bit more time and money but it might be worth it for your piece of mind
qiumaoyuan (05-17-2025)
maintanence, oil changes, track days
oil change/fluid maintenance intervals for track car? Turbo Tracking / Autocross / HPDE / Drifting 12 07-25-2021 02:44 AM
Oil change intervals America vs Europe NordicGT86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 06-14-2018 08:59 PM
Oil Change Intervals (Winter Storage Advice) Mr.Impreza Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 10-21-2016 04:09 AM
What are the oil change intervals listed for 2015 cars? pantdino Issues | Warranty | Recalls / TSB 8 09-06-2015 01:36 PM
Oil change intervals? nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-10-2014 04:06 PM
