Old 10-17-2016, 07:46 PM   #1
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Oil Change Intervals (Winter Storage Advice)
Hey guys. Just need advice on the following oil change interval options.
I drive about 10,000KM (about 6000 miles) per year.
My question is, how should i go forward with oil changes.
Option 1
Change oil in November/or (when i put it in winter storage)
Change oil in May *6 month interval* (I bring out the car usually in March/April so i would drive with the oil that was in storage for 1-2months)
Option 2
Change Oil in November/or (when i put car into storage)
Change Oil in March/April (when I bring car out of storage)
My issue with Option 2 is that I would drive almost 8 months with the same oil when I heard you should change oil every 6 Months if you don't reach your necessary miles.
While option 1 it would be an evenly 6 month interval.
So advice would be much appreciated.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 10-17-2016, 08:01 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
I will be driving about the same as you. 10K/year in the warmer months
I plan on doing the oil first thing in the spring and around August/September.
It's overkill but not by too much.
Old 10-17-2016, 11:29 PM   #3
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
So I'm just going to do this starting from this year. (Assuming all changes are done on the 1st day of the month)
Change Oil in December (Before Storage)
Change Oil in April (When Taking out of storage)
Change Oil in August
That way my intervals will be every 4 months.
Old 10-18-2016, 12:27 PM   #4
humfrz
I don't think it would make a damn bit of difference to the car ......
humfrz
Old 10-18-2016, 12:31 PM   #5
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
This is easy... Drive more!
seriously, what Humfrz said.... you'll be fine w/ any of those plans. The three changes a year scenario is probably overkill.
MuseChaser is offline   Reply With Quote
Old 10-18-2016, 12:52 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
humfrz
Funny, after I responded I googled "oil changes and winter storage"
Your response was pretty much the same on a Miata forum.
Old 10-18-2016, 05:30 PM   #7
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
humfrz
Oh okay. So I will probably than just do the oil change before winter storage and oil change when bringing out of storage
I just wanted reassurance that 7-8 months in between would be fine.
Old 10-19-2016, 07:35 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
From my understanding oil itself doesnt significantly age. Therefore the interval is irrelevant if the engine isn't in use.
I do the same mileage as you and I will store the car immediately after an oil change and fuel stabilizer. Also using a battery tender.
Some time during summer I do an oil change at 5000 km then the next before storing. Two changes a year in 10000 km.
Old 10-19-2016, 10:03 AM   #9
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Bradley, so then would I be fine with using the oil that was in storage? Because I'd prefer option 1.
Option 1
I just heard people say moisture builds up so it's why I'm confused about it.
Anyways if you are doing it that way, than I think I'll do the same since I like that method the best. Just feels like such a waste of new oil to e drained out when I didn't even use it.
Old 10-19-2016, 10:24 AM   #10
jasonojordan
Drives: 2013 satin white brz limited
The main killer while storing a vehicle over winter is temperature swings. Try and keep the area where you store it a some what stable temperature. Large swings can cause condensation and that is where you will get your issues from.
jasonojordan is offline   Reply With Quote
Old 10-19-2016, 11:08 AM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
The issue with moisture is almost the same as people that take frequent short trips in the winter. The sudden heat causes condensation when in contact with the freezing air.
The best thing to do (not that I have) is to never start the car even once all winter.
Otherwise condensation is released, or specifically from the oil, when oil temps exceed 100'C as it will with normal use.
I am not sure how you store a vintage Bugatti but this is a normal car.
Old 10-19-2016, 11:33 AM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
This is a pretty big topic on BITOG.
General consensus: As long as you use synthetic, and basically get the vehicle to operating temperature if you start it during storage times you won't degrade the oil and can basically go all your storage time and use it like normal mileage wise.
The only way to be sure though, is if you get the blackstone test. Condensation was brought up earlier in this thread, and that is the main worry (why you're bringing the vehicle to operating temp when / if it is started).
Personally, I just go off mileage and use a good oil. Even doing regular oil changes is probably overkill according to all the testing on current synthetic oils.
You're not storing the car for years at a time in this situation. I don't think starting it up / driving it here and there during "winter storage" is a bad thing since it gets all the parts moving for a little while at least.
Old 10-19-2016, 09:11 PM   #13
D_Thissen
D_Thissen's Avatar
Leave the current oil in the car, and change it in the spring. No reason to change it now, park the car, then change it in the spring. You're wasting money.
Old 10-21-2016, 01:19 AM   #14
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I realize you're more concerned with time than mileage in this thread, but FWIW I just added this post to my blog today which you might find interesting. It includes all the oil analysis results from my oil changes, which I do every 10,000 miles (~16,000 km), which for this latest change, happened 6.5 months apart.
http://www.seriesblueadventures.com/...-oil-analysis/
Stang70Fastback is offline   Reply With Quote
winter storage... what are you doing? sledheadguy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 92 11-22-2016 02:37 PM
What's a reasonable starting point for fluid change intervals? hpde_addict Tracking / Autocross / HPDE / Drifting 14 09-16-2016 07:42 PM
What are the oil change intervals listed for 2015 cars? pantdino Issues | Warranty | Recalls / TSB 8 09-06-2015 01:36 PM
Oil change intervals? nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-10-2014 04:06 PM
Change oil before or after winter storage... or both? switchlanez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-07-2012 04:30 PM
