Old 05-14-2025, 01:19 AM   #1
Limitz
Drives: Black Scion FR-S
Question about coolant. I have red coolant in my 2015 Frs
So ive had my 2015 frs for 2 years, (some background) i recently started putting A LOTTT of miles on it like 200 daily 5 days a week, Car is running great everything good, temp doesn’t fluctuate it’s a 2 hour drive and it usually ends off at like 35-50% on the temp gauge. I just became worried because I saw another brz with blue coolant. So I searched it up online and it says gt86/frs/brz should run blue coolant. Well my car has been running red coolant for 2 years and levels are always fine, temp is good, car itself is good. Should i worry bout it and flush it to put the correct (blue) coolant? Or it don’t matter ?
Limitz is offline   Reply With Quote
Old 05-14-2025, 05:18 PM   #2
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
If your car's temperatures are normal and you've been using the same coolant for 2 years without any issues, switching back to OEM doesn't seem like a problem if you want to ease your mind.
ZC6_STi is offline   Reply With Quote
Old 05-14-2025, 05:43 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
The problem with the wrong coolant is not that it won't cool the engine sufficiently (plain water will happily do that), but that it will cause corrosion in the engine, cooling system, or both. I would recommend putting the correct coolant in with as thorough of a flush as you can.
Also note that the color of the coolant is typically a decent indication of its compatibility, but not an absolute one. Make sure to use coolant that is compatible with the engine (sadly coolants don't use type certification/specification like oils (engine, transmission, etc.), so it's hard to recommend anything specific other than "go to the manufacturer website and check compatibility with your car").
My owner manual (2018 BRZ) just says:
* SUBARU Super Coolant
* Similar high-quality ethylene glycol-based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology
Ohio Enthusiast is offline   Reply With Quote
OEM Toyota Blue Super Long Life Coolant == Super Coolant Pre Mixed? bakingpancake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-15-2022 12:24 PM
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
