Old 05-05-2025, 12:19 PM   #1
smoltz
Drives: 01 911 Turbo, 03 G500
Fuel Cutout @ High RPM in 4th Gear
Anyone here experience fuel cut out at high RPM on track? Stock FA20 w/ Tune+Headers.
This was on a straight after a mid-g left hander.
I had about 3/4 tank of fuel, maybe a little less. Getting what I suspect was fuel cut out at high RPM in 4th, felt like I was hitting the limiter but I wasn't even close to it.
Is there a good way to verify this? Other than just replacing/upgrading fuel pump.
I see some older bosts about flapper mods and such but seems like DW300C fuel pump is the permanent solution?
Thoughts? Suggestions?
smoltz is offline   Reply With Quote
Old 05-05-2025, 08:29 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Left hand turn. Fuel pump/pickup is on the left side it’s even worse with e85. The Verus fuel door helps some.
Old 05-05-2025, 09:37 PM   #3
smoltz
What's the "proper" fix here?
Old 05-05-2025, 09:47 PM   #4
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The Versus flapper valve lets you run longer without fuel cut, but to completely fix the issue you'd need a surge tank, auxiliary or transfer pump, or fuel cell.
14stu is offline   Reply With Quote
Old 05-06-2025, 06:30 AM   #5
smoltz
Maybe I'll start with the Verus flap and go from there.
This is a video of what's happening....
In the video you'll see throttle goes to zero but that's cause I'm logging TPS not PPS (although I think I have the data for that in another file). I am 100% on the pedal. Seems like fuel starvation, car cuts throttle?
Is there any way to confirm that it's fuel starvation?
Old 05-07-2025, 04:54 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That doesn’t sound like fuel cut to me. When it fuel cuts on my car it feels like it bogs. It also usually fuel cuts mid corner to track out depending on corner type/length. That sound kinda reminds me of bad DI seals. What do you have for logging data on car?
Old 05-07-2025, 07:56 AM   #7
smoltz
Interesting. This was happening at the end of a short straight after a left hand turn, and I made it out of the turn through the top of 3rd into 4th with no issues. It did the exact same thing multiple times, but only at top (6500+) of 4th.
While on track it was just my AIM running with stock ECU profile, so not much, just pedal position, throttle position. Car has stock ecu with ECUtek so theoretically if I can reproduce I can use their logging feature.
Assuming I could get the ecutek logging setup and reproduce what should I be looking for?
Old 05-07-2025, 02:07 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d talk to your tuner and see if he is willing to help you setup logging. If not someone else should be able to help you from here. You should be able to log it. I’m an OFT peasant so out of my wheel house.
Old 05-07-2025, 07:03 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Um, I had a similar issue, chased "fuel starvation", installed flapper valve, no joy. turns out the tune cut power if oil temp went above 275F! Dam... So yeah, check with tuner...
4th Gear Crunch at high RPM (not grind) draculr Engine, Exhaust, Transmission 6 12-09-2021 12:30 PM
6000-7000 RPM 3rd-4th Gear Noise tahoward Issues | Warranty | Recalls / TSB 14 03-29-2016 04:46 PM
High RPM 3rd to 4th Shift Crunch calmtigers Issues | Warranty | Recalls / TSB 1 08-01-2014 07:08 PM
Low Torque @ High RPM VS High Torque @ Low RPM Mikeez Other Vehicles & General Automotive Discussions 41 02-20-2014 01:18 PM
RPM drops twice after shifting to 3nd gear at ~2500 RPM anewprelusion Issues | Warranty | Recalls / TSB 3 12-23-2013 02:42 PM
