Old 11-13-2019, 11:18 PM   #1
draculr
Drives: Toyota 86 GTS
4th Gear Crunch at high RPM (not grind)
Hey guys, I've been reading a lot of threads about 4th gear grind at high rpms and people getting their transmissions replaced.
I'm guessing by grind people are talking about this: [ame]https://www.youtube.com/watch?v=G6EUWndrqWU[/ame]
My car (2017 86) has a bit of a notchy "crunch" feeling and sound but not a grind as the video above has. I still have a few months of warranty remaining so i'm not sure if it's worth taking it in for that. Is it something where my crunch will turn into a grind soon enough?
draculr is offline   Reply With Quote
Old 11-13-2019, 11:52 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, not synchro by chance, if it's only when engaging, not while driving in gear? Still, if you have warranty, i'd use it while car still in it.
Old 11-14-2019, 02:12 AM   #3
draculr
It's just when engaging 4th gear at higher RPMs. Starting around 4,000rpm or so and getting worse the higher up it gets. But much more like a crunch than an actual grind like in the video above.
I may still take it in and let the dealer tech have a look.
Old 12-06-2021, 11:47 PM   #4
BleedingRust
Drives: BRZ S
What did you end up doing? My bought it used and no warranty so trying to see what I could do without rebuilding the thing.
BleedingRust is offline   Reply With Quote
Old 12-07-2021, 12:03 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
OP was last online a year and a half ago... I doubt you're getting an answer here.
1974 TA22 Celica
2013 86 GT
Old 12-07-2021, 09:02 AM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
When you can, post a video of the car making the noise.
Old 12-09-2021, 12:30 PM   #7
Autoxer62
I'd try a different fluid. I had a crunch going into 3rd so I just changed it it for Redline and got better shifting at redline. What came out of the trans didn't fill me with confidence in terms of the transmission's life if owned by a 'sporting' driver, I was glad to get it out of there.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
4th to 5th gear grind. allowe Engine, Exhaust, Transmission 23 07-26-2017 02:53 PM
1st gear crunch twisting sound Drambeenie BRZ First-Gen (2012+) — General Topics 37 03-10-2017 04:26 PM
High RPM 3rd to 4th Shift Crunch calmtigers Issues | Warranty | Recalls / TSB 1 08-01-2014 07:08 PM
Second Gear Crunch? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 18 09-27-2012 02:52 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
