Drives: 14 FRS Monogram, 05 Mazdasped Miata
OFT won't respond
2014 FRS. I just went back to my original OEM catted header and planned to flash my OFT accordingly. I'm running a Phantom Electric Supercharger with 93 octane and the current tune is for stage 2, which is for catless. I plugged my OFT into my computer and started the manager just to see what I had, and it went through a great many updates, then asked me to approve a new software version. I was concerned at that point because it's been three or four years and I didn't know if the new software would recognize the codes that are on my OFT, so I declined.
I plugged the OFT into the car, but when it tells me to turn on the ignition and press OK for the tune, It won't respond. I tried a stylus and that didn't work either. I can't get to the tunes that are on my OFT. Maybe I don't have any choice but to install the new software on the OFT and hope it will work then. It's pretty worrisome. I don't want to end up with a brick Can anyone advise? |
29 visits and no response. That's not very encouraging. I think I'm dealing with a bad OFT. I recall when I put the last tune in it seized up two or three times and the only way I could get it going again was unplug and plug it back in. So I think if I buy a new OFT and download that file which is available from OFT and which I have in my file manager anyway, I can probably install the proper tune.
Running a tune for catless into a catted header means a rich mixture which might damage the current header, so I better get to it. There's an Ecutek guy here in town. I talked to him and he said they can sometimes fix it but it has a possibility of bricking the ECU as well. |
Drives: 17 Asphalt 86
If you have Facebook there is an open flash tablet FRS/BRZ tuning and support group. You'd probably have more luck on there given forums have slowed down a lot after it bugged out for several months.
Famous Potatoes
Drives: '15 ultramarine
Fixed it!
I'm running an ESC, so my starter battery is for a motorcycle. I got to thinking that battery might be a little weary at this point anyway, so I charged it overnight and left it on charge. The tune went through without a hitch.
Drives: SWP BRZ
i'm having my OFT issue too. i havent used it for long time and updated it and can't load any tune in tablet.
https://www.ft86club.com/forums/showthread.php?t=155856 i sent e-mail to openflash and hopefully they do something about it. |
| Keyless entry VERY slow to respond. | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 10-02-2017 10:30 AM |
| Car won't start, won't crank, no ecu communication | redlined600 | Issues | Warranty | Recalls / TSB | 10 | 07-09-2016 12:55 PM |
| FA20CLUB, please respond to me regarding my header purchase . | Vten | Engine, Exhaust, Transmission | 18 | 08-04-2013 08:52 PM |
