Old 04-22-2025, 04:44 PM   #1
smoltz
Drives: 01 911 Turbo, 03 G500
CAN Options Connector in Gen 1
IIRC the car has several CAN Busses.
Does the CAN options connector behind the radio have all the same data as the CAN Wires on the OBD2 port?
Trying to figure out where to tap in for AIM SOLO2 DL
smoltz is offline   Reply With Quote
Old 04-22-2025, 05:24 PM   #2
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Responding mostly because I also want to know.
However, CAN is a "bus" meaning that, if there is a connector behind the radio, it's all the same CAN bus. My understanding is that CAN bus is a protocol based communication method and the wiring should be consistent.
But, I'll let more knowledgeable people respond.
RongTurnRacing is offline   Reply With Quote
Old 04-22-2025, 05:43 PM   #3
2.2Lude
2.2Lude's Avatar
I believe so but cannot confirm. I have a GJP Trac-box hooked up via the connector behind the radio and run my SoloDL off the standard OBD2 port.
2.2Lude is offline   Reply With Quote
Old 04-24-2025, 11:47 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I run an AIM SOLO 2 DL from the option connector; no issues with the AIM data profile
EndlessAzure is offline   Reply With Quote
Old 04-24-2025, 02:05 PM   #5
I just run it off of the OBD2 port
Old 04-25-2025, 02:48 PM   #6
RedReplicant
Drives: None
There is only one network on a stock gen 1, so wherever you pick up your CAN Hi / Lo will have the same data.
Since this post will inevitably come up in the future via Google search or whatever - if you have something like a motor swap with Haltech you will want to connect your data logger to the second Haltech network, not the chassis one. The relevant chassis messages like individual wheel speeds will be available in the Haltech broadcast protocol alongside the usual Haltech messages with things like coolant temp, oil pressure, etc.
RedReplicant is offline   Reply With Quote
Old 05-05-2025, 12:10 PM   #7
smoltz
Cars can have multiple busses. Apparently the Gen 1 BRZ only has one though. IIRC the gen 2 has multiple, that was the basis for the question. I used to have a gen2 and have moved to a gen1.
For the next person who finds this thread. I ended up running off the option connector as well. I have a GJP trac-box so I ended up just making the GJP harness that goes from the options connector to the tracbox into a Y harness with the AIM cable cable as well. Nice and tidy.
Good stuff, thanks!
Old 05-05-2025, 12:23 PM   #8
RongTurnRacing
That's good to point out. Not long after I posted, I realized that some cars have multiples. Apparently, the Link ECU I run has two CAN interfaces.
So how much is the Gen 2 performance worth for Gen 1 owners Ernest72 GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 08-31-2021 09:53 AM
Compatible parts from 1st gen to 2nd gen? Good idea? chazmuska GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-30-2021 09:32 AM
Motor1's Gen 1 vs Gen 2 visual comparison WorldRallyB GR86 General Topics (2nd Gen 2022+ Toyota 86) 18 07-06-2021 07:00 AM
What will happen to first gen brz/gt86 when the second gen comes out? Maheralfa Scion FR-S / Toyota 86 GT86 General Forum 42 06-18-2021 10:08 AM
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
