Old 04-18-2025, 12:31 AM   #1
Mont-E
Drives: Scion FR-S
Question Wheel stud removal question (without removing rotor)
Hi
I have a stripped wheel stud on the front that I need to replace. All the videos/guides I have gone through suggest this:
1. Remove brake caliper
2. Remove rotors
3. Remove old stud
My question is, can I just not hammer the old wheel stud out without removing the rotor? Why not?
If I can, I am hoping to slide the new wheel stud in, maybe put a tape or something behind it to somewhat hold it in place. Put the lug nut over the rotors to pull the stud in. Any issues with this?
My reason for this is, trying to avoid taking the rotor off, if I can as it's usually stuck pretty good.
2015 Scion FRS
Thank you
Mont-E is offline   Reply With Quote
Old 04-18-2025, 04:07 PM   #2
gpvecchi
gpvecchi's Avatar
It works, but there's just one position of the hub that lets the stud slide out.
gpvecchi is offline   Reply With Quote
Old 04-19-2025, 12:06 PM   #3
WNDSRFR
Drives: FR-S,GTI
https://www.ft86club.com/forums/showthread.php?t=69011
Pops right off.
Old 04-26-2025, 09:46 AM   #4
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
One downside I have seen people discuss is that hammering out the stud puts stress on the bearings and other parts that you are hammering against. If doing one stud I would not worry about it. I have seen MANY people beat these out in videos without issue. Make sure you have a plan to install the new stud.
TStafford is offline   Reply With Quote
Old 04-28-2025, 08:44 AM   #5
Tokay444
Anti stance.
Tokay444's Avatar
Why not just take the caliper and rotor off?
Removing rear knuckle while rotor/caliper is still on - possible? series.trackday Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-26-2023 03:30 PM
Stud replacement without removing rear hub? Impureclient Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 02-06-2021 05:01 PM
Seized brake rotor removal tool fstlane DIY (Do-It-Yourself) Guides 15 09-06-2015 12:38 AM
DIY: removing the head unit without tears robot DIY (Do-It-Yourself) Guides 3 10-22-2014 08:15 PM
Best way of removing Bugs without damaging paint? tacoss23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-01-2013 12:13 AM
