Old 03-25-2025, 10:45 PM   #1
jake18hunter
Drives: X-runner
Engine Noise
Would like some input on what you think is wrong with my frs
https://youtube.com/shorts/HaqwhHpixXk?feature=share
jake18hunter is offline   Reply With Quote
Old 03-25-2025, 10:55 PM   #2
callisto
Drives: 2019 Subaru BRZ
That sounds a lot like this video:
callisto is offline   Reply With Quote
Old 03-25-2025, 11:04 PM   #3
jake18hunter
Drives: X-runner
Mine only makes the noise when I rev the engine not at idle. Personally it doesn’t sound like knocking to me
Old 03-25-2025, 11:07 PM   #4
callisto
Is your AC turned to auto / on? Try turning the AC off and see if it stops?
Old 03-25-2025, 11:22 PM   #5
jake18hunter
Drives: X-runner
It started doing this after my engine basically turned itself off. I cranked it back up and pulled off to side of road. I popped hood to check to see what happened because I smelled electrical or rubber smell. Engine was making weird popping noise but went away. Iwas driving home and decided to put in manual mode and 1st gear sounded like this video until I shifted and went away. I can drive car but sometimes when I’m driving around 55 the noise will try and come back. Also I did drain a little oil and it contained copper glitter. I haven’t dropped oil pan to see everything. Just wanted some input to see if it could maybe be timing chain
Old 03-27-2025, 01:59 AM   #6
tomm.brz
Drives: brz 2017 hksv2
no. it s rod knock90%, also you started to do more damage the moment you turned on the car after it shut itself off (not that s your fault)
Do not start it ever again.. you ll need a new short block if so and very tedious cleaning job because the glitter went everywhere
Chains and retainers is also a good idea to put new
or could be a rocker arm
Old 03-28-2025, 12:24 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pull an oil sample and send it off. Easy way to confirm without tearing anything apart. I wouldn’t run it until then.
Old 03-28-2025, 03:21 AM   #8
callisto
If you’re lucky it might just be a bearing but you are absolutely in the realm of “tow don’t run to your nearest engine expert”
Engine ticking noise after spark plug job ThatGuyWithAnFRS Issues | Warranty | Recalls / TSB 3 02-02-2023 10:07 AM
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
