Drives: 14 FRS Monogram, 05 Mazdasped Miata
What is the currently-recommended fire extinguisher and where can i get one? I haven't been on track for quite a while but we always used Halon, which I understand may have been outlawed now. I see some CO2 extinguishers but don't see anything that looks like the right size for use in a car, I would never use a dry chemical fire extinguisher on a car fire. You'll never get all that crap out of the car.
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I have a pretty nice one, which I bought on accident because I'm dumb. I meant to buy a system with the nozzles and bought a hand held.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
Drives: 2013 Subaru BRZ Turbo
What did you buy? I have one of the stick ones that were all the rage last year but I don't have a ton of confidence in it. I mostly only do SCCA Solo and Time Trials but I feel like it's a better safe than sorry kind of thing.
lifeline zeo
Drives: Crapcan
I plan on running one of those and a full size. I’ve seen 3 cars burn from not having adequate fire suppression. And boxers having the exhaust under the engine a bad failure could dump oil in it.
That's a good point. I have a small one but a full size is certainly something to consider. Figuring out the capabilities seems to be the next challenge I have to figure out.
#7 | |
When it's dry out, if you spin and get stuck, you're very likely to start a fire if you're on anything resembling brush. If that happens, the first thing I do is hop out and spray underneath the car so the fire doesn't start, or if it does, hopefully put it out before it gets too big. Fire safety system is just that- a SAFETY system, not a vehicle protection item. It won't stop your car from burning to nothing. It will give you more time to get out.
#8 | |
Drives: Crapcan
Wheels for Brains
I use a 2kg Lifeline Zero handheld, strapped to a Scott Drake Quick Release Mount, and bolted to an F4 Fab floor bracket
#10 |
Interesting, but none of this answers my original question. What compound is in general use today? Halon, CO2, dry chemical or something else? I would only use a dry chemical extinguisher as an absolute last resort. You'll play hell getting all that crap out of the car afterward. And if someone hits it with a liquid on top, you may never get the mess cleaned up.
#11 | |
Wheels for Brains
The 2kg is FIA for on-board handheld. I'm sure anything from the current FIA/SFI reg list for plumbed-in or onboard is going to be a good bet, most being Novec/FK or AFFF FIA Tech List 6, 16, & 52 Last edited by EndlessAzure; 02-17-2025 at 04:43 PM. |
| fire extinguisher mounts? | Lebby83 | Tracking / Autocross / HPDE / Drifting | 33 | 06-09-2023 08:32 PM |
| Mounting a Fire Extinguisher | Xauterus | AUSTRALIA | 37 | 05-21-2017 05:15 PM |
| Fire Extinguisher in Trunk | tofurun | DIY (Do-It-Yourself) Guides | 10 | 09-04-2016 09:56 AM |
| Fitting a fire extinguisher in your car. | TheBracketeer | Interior Parts (Incl. Lighting) | 1 | 09-01-2015 01:14 PM |
| Fire Extinguisher | sw20kosh | Tracking / Autocross / HPDE / Drifting | 5 | 08-08-2013 04:28 PM |
