Old 02-12-2025, 04:09 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Question Proper fire extinguisher
What is the currently-recommended fire extinguisher and where can i get one? I haven't been on track for quite a while but we always used Halon, which I understand may have been outlawed now. I see some CO2 extinguishers but don't see anything that looks like the right size for use in a car, I would never use a dry chemical fire extinguisher on a car fire. You'll never get all that crap out of the car.
Qwimby1 is offline   Reply With Quote
Old 02-12-2025, 06:08 PM   #2
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I have a pretty nice one, which I bought on accident because I'm dumb. I meant to buy a system with the nozzles and bought a hand held.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 02-12-2025, 07:47 PM   #3
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
What did you buy? I have one of the stick ones that were all the rage last year but I don't have a ton of confidence in it. I mostly only do SCCA Solo and Time Trials but I feel like it's a better safe than sorry kind of thing.
RT-BRZ is online now   Reply With Quote
Old 02-13-2025, 07:05 AM   #4
GrandSport
GrandSport's Avatar
lifeline zeo
The Following User Says Thank You to GrandSport For This Useful Post:
RT-BRZ (02-13-2025)
Old 02-13-2025, 12:34 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I plan on running one of those and a full size. I’ve seen 3 cars burn from not having adequate fire suppression. And boxers having the exhaust under the engine a bad failure could dump oil in it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
RT-BRZ (02-13-2025), Ultramaroon (02-13-2025)
Old 02-13-2025, 12:35 PM   #6
RT-BRZ
RT-BRZ's Avatar
That's a good point. I have a small one but a full size is certainly something to consider. Figuring out the capabilities seems to be the next challenge I have to figure out.
Old 02-13-2025, 03:57 PM   #7
GrandSport
GrandSport's Avatar
I have a full fire system and 2 small extinguishers. Why?
When it's dry out, if you spin and get stuck, you're very likely to start a fire if you're on anything resembling brush. If that happens, the first thing I do is hop out and spray underneath the car so the fire doesn't start, or if it does, hopefully put it out before it gets too big.
Fire safety system is just that- a SAFETY system, not a vehicle protection item. It won't stop your car from burning to nothing. It will give you more time to get out.
The Following 2 Users Say Thank You to GrandSport For This Useful Post:
NoHaveMSG (02-13-2025), Ultramaroon (02-13-2025)
Old 02-13-2025, 06:25 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s kinda my thinking. Especially since I can easily fit two in the center console. One car I saw burn was an S2k that had brake failure and was in the grass between two marshal posts so they had to wave the red and get all cars stopped before the course marshals could go to them. It took a while and he had nothing. I figure anything to buy time is good.
Old 02-14-2025, 08:11 AM   #9
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I use a 2kg Lifeline Zero handheld, strapped to a Scott Drake Quick Release Mount, and bolted to an F4 Fab floor bracket
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
NoHaveMSG (02-15-2025), RT-BRZ (02-14-2025)
Old 02-15-2025, 11:42 AM   #10
Qwimby1
Interesting, but none of this answers my original question. What compound is in general use today? Halon, CO2, dry chemical or something else? I would only use a dry chemical extinguisher as an absolute last resort. You'll play hell getting all that crap out of the car afterward. And if someone hits it with a liquid on top, you may never get the mess cleaned up.
Old 02-17-2025, 04:30 PM   #11
EndlessAzure
Wheels for Brains
Lifeline Zero is 3M Novec / FK; a quick google search away
The 2kg is FIA for on-board handheld. I'm sure anything from the current FIA/SFI reg list for plumbed-in or onboard is going to be a good bet, most being Novec/FK or AFFF
FIA Tech List 6, 16, & 52
The Following User Says Thank You to EndlessAzure For This Useful Post:
RT-BRZ (02-17-2025)
fire extinguisher mounts? Lebby83 Tracking / Autocross / HPDE / Drifting 33 06-09-2023 08:32 PM
Mounting a Fire Extinguisher Xauterus AUSTRALIA 37 05-21-2017 05:15 PM
Fire Extinguisher in Trunk tofurun DIY (Do-It-Yourself) Guides 10 09-04-2016 09:56 AM
Fitting a fire extinguisher in your car. TheBracketeer Interior Parts (Incl. Lighting) 1 09-01-2015 01:14 PM
Fire Extinguisher sw20kosh Tracking / Autocross / HPDE / Drifting 5 08-08-2013 04:28 PM
