Old 01-27-2025, 12:29 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Brz goes into limp mode without any CEL
Really bizarre.
ONE TIME, I got a code, u0155- loss of comm with instrument cluster. Other than that, limp mode many times, no CEL.
It just cuts a ton of power to where it’s barely able to hold 50mph.
Dedicated race car.
The only pattern I can see is- it’s most common after I run a few sessions, then break for lunch, then drive again. It’s after the long break that it does it. Almost never in the first 2 sessions.
anyone have any ideas?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 01-27-2025, 01:26 PM   #2
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Originally Posted by GrandSport View Post
Really bizarre.
Dedicated race car.
Pinched/frayed/exposed wire somewhere?
RongTurnRacing is offline   Reply With Quote
Old 01-27-2025, 01:32 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
How are you pulling this code? Are you using a code reader to clear the CEL or actually digging into it with ECUtek or whatever your tuning platform is?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 01-27-2025, 02:55 PM   #4
GrandSport
GrandSport's Avatar
just a code reader.
Old 01-27-2025, 02:56 PM   #5
GrandSport
GrandSport's Avatar
man, there's a lot of wires! but we were looking
Old 01-27-2025, 03:10 PM   #6
RongTurnRacing
Yeah, I knew that would be the unfortunate case when I said it. You're racing it so you never know what might be rubbing or lose or something silly because of the conditions.
Old 01-28-2025, 08:54 AM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Does it clear up on it's own? Or after you clear the code? You really need a datalog while it's misbehaving.
Old 01-28-2025, 05:45 PM   #8
GrandSport
GrandSport's Avatar
I shut it off, start it back. Sometimes it get better. sometimes it doesn't.
Old 01-28-2025, 10:20 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is going to be a tough one. Does it only rev to a specific RPM in limp mode? There is a chart in the online manual with the fail safe condition associated with certain DCT’s, even though you aren’t getting any may help narrow the search.
Old 02-11-2025, 05:30 PM   #10
GrandSport
GrandSport's Avatar
This was definitively determined to be the AIM dash.
How to Fix Limp Mode? MidnightFumes Issues | Warranty | Recalls / TSB 7 01-20-2021 05:18 PM
Limp mode at 2K rpm NEED HELP!! Arthur_frs Engine, Exhaust, Transmission 5 04-13-2020 10:22 PM
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
