Drives: 2013 FRS
Limp mode at 2K rpm NEED HELP!!
Hello guys, just purchased a 2013 FRS, drifted it for 40 min and then went to limp mode, I start up the car it’s fine until I turn to the right and then goes into limp mode again. I ran the codes I’m getting a EVAP system code. I have cleaned the MAF took off the manifold checked for any loose hoses etc everything is in place I really need help.
Keep in mind this car is a “drift build” has no AC no TC and no ABS it has been removed Codes I got P0453 P2419 |
Might as well remove the evap too. Have to turn off the code in the tune though
Sent from my ONEPLUS A5010 using Tapatalk |
Drives: 2013 FRS
Bump really need help
Drives: 2013 FRS
Canister is above your differential. You can just unplug from engine and turn off codes though. Might have to plug up some holes to avoid vacuum leak. If it's a half stripped drift missile there's no point in maintaining emissions equipment
| Limp mode | GTBOY | Issues | Warranty | Recalls / TSB | 4 | 06-07-2018 12:58 PM |
| Valet mode / limp mode? | radroach | Software Tuning | 1 | 09-18-2017 11:34 AM |
| How to limp mode.. | vichiball | Software Tuning | 5 | 07-12-2016 01:18 PM |
| Limp mode AFTER clearing CEL | white_knight | Issues | Warranty | Recalls / TSB | 8 | 03-30-2016 08:40 PM |
| Car in Limp mode... No CEL | Sportsguy83 | Issues | Warranty | Recalls / TSB | 60 | 08-20-2014 03:35 AM |
