Old 01-03-2025, 01:02 PM   #1
twodollarcuts
Drives: Subaru BRZ Limited
Weird clicking coming from behind engine block/transmission area
Not sure what this sound is. Just noticed it a few days ago. I can hear it fairly well within the cabin. Any suggestions for what to check would be appreciated.
update: noise is consistent now
https://youtube.com/shorts/XjWbtJeibp8?feature=share
twodollarcuts is offline   Reply With Quote
Old 01-03-2025, 02:04 PM   #2
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
https://youtube.com/shorts/a5KJY8ECBfg?feature=share
I would guess clutch and related parts.
RongTurnRacing is offline   Reply With Quote
Old 01-03-2025, 02:49 PM   #3
twodollarcuts
It essentially sounds like metal clanging against each other right now and it's super consistent. I updated the video post if that helps.
Old 01-03-2025, 03:59 PM   #4
RongTurnRacing
Based on where it's coming from, I would say clutch, flywheel, throw out bearing, etc. The fly wheel, throw out bearing, clutch and pressure plate are always spinning so that's why it would be a consistent sound.
Otherwise, it's something much worse.
Old 01-03-2025, 10:50 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I would immediately drop the transmission and see what is going on.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 01-04-2025, 10:56 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I recommend one test before you pull things apart.
Does the sound go away or change when you press the clutch pedal? If so the issue is on the transmission side of the clutch. If not the issue is on the engine/bellhousing side.
It's definitely not a "it'll be fine if you leave it alone" kind of sound though.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 01-05-2025, 08:26 PM   #7
twodollarcuts
It does not go away when I press the clutch. I'm taking it in tomorrow. Fingers crossed that it's not too bad.
Old 01-07-2025, 10:53 PM   #8
twodollarcuts
Ended up being a loose bolt on the torque converter. Dealer repaired it, no charge, so big shoutout to Gillman Subaru.
Old 01-08-2025, 10:27 AM   #9
DarkPira7e
DarkPira7e's Avatar
I hope they're mincing words, you don't have a torque converter. Glad they fixed whatever it was regardless!
Old 01-08-2025, 09:54 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Maybe that was the problem all along. All that extra shit rattling around in there.
Old 01-16-2025, 04:15 PM   #11
Spuds
The Dictater
Spuds's Avatar
Or there's actually no clutch pedal lol.
Old 01-16-2025, 08:31 PM   #12
Ultramaroon
not playing cards
That's how they feel from the factory
Old 01-16-2025, 10:17 PM   #13
Spuds
The Dictater
Spuds's Avatar
Slave cylinder mod is still 10/10
Old 01-16-2025, 10:26 PM   #14
Ultramaroon
not playing cards
WTB: FA20 Engine (long block or short block) GrandSport Want-To-Buy Requests 3 02-23-2023 08:20 AM
Weird clicking noise Jonbonilla Issues | Warranty | Recalls / TSB 4 07-22-2019 11:07 AM
Weird noise coming from engine Qball1754 Engine, Exhaust, Transmission 11 05-28-2019 01:17 AM
Eibach Sportline Weird Clicking Noise coming from car VeganGirl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-25-2016 03:19 PM
weird noise sound coming around header area shern Issues | Warranty | Recalls / TSB 28 02-19-2016 07:39 PM
