Drives: Edelbrock Supercharged 2015 FRS
FRS Fluttery chirp rattle thing
Howdy gang. I split the bellow/flex pipe of my header open so I got a new flex pipe welded in. I will note that the welds are good and there are no leaks from the header. After I got the new FP welded on, it sounds tremendously more correct than it did with a hole in the header, but there’s now a weird almost fluttery sound. I’ll see what I can do about attaching a clip. I mostly want to believe this is attributed to the new flex pipe, as change made->new sound (logically). It could be the sound of the exhaust gasses hitting the thin stainless, or it could be worse. I figured I’d just run it by the think tank first. (It also could potentially be the d4s stuff but I don’t think so). Sound is only really there when engine is under load of accelerating/maintaining speed unless I’m super gentle. Not higher revs like above 4-4.5k though.
2015 frs Edelbrock SC on flex fuel Header is PLM https://youtube.com/shorts/KeLGqnQjt...4PXCl76FgYqshy Flutter sound at 3 second mark and 5 second mark (1st and 2nd) |
Drives: 17 Asphalt 86
I'd consider a new header. PLM are bottom barrel in terms of quality. No Current headers use flex pipes as they always fail.
Gruppe-s, MXP, GUMotorsport are inexpensive options. Or find used tomei. |
Drives: Crapcan
Flutter and chirp sounds like exhaust leak.
| Anyone one flashed back and had a problem at the dealer? (chirp chirp chirp) | OkieSnuffBox | Software Tuning | 16 | 11-18-2014 04:56 PM |
| Chirp Chirp Chirp | TheseColorsDontRun | Mid-Atlantic | 26 | 09-18-2013 11:36 PM |
| Random Chirp while moving. NOT idle chirp. | Stephens | Issues | Warranty | Recalls / TSB | 18 | 08-14-2013 12:02 PM |
| Chirp Gone Nothing Replaced | Employee | CANADA | 6 | 08-04-2013 12:25 PM |
| Help me ID this chirp | nix | Issues | Warranty | Recalls / TSB | 3 | 02-07-2013 08:00 AM |
