Old 11-18-2024, 04:52 PM   #1
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
FRS/BRZ Direct Injection Question
I have a question. What happens if the direct injectors are not installed in the order they are taken out?
I have a built IAG block/head combo and I'm trying to chase down some misfires on idle.
I had the port injectors cleaned and everything by Southbay Fuel Injectors however i have no idea if the shop installed them in the order they were taken out or if that would call for a missfire.
Any help would be appreciated.
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
KxngCorey is offline   Reply With Quote
Old 11-18-2024, 09:45 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I installed totally different, freshly cleaned injectors with new seals and no care for order or the number on the injector.
Is the misfire limited to idle or does it get more intense with RPM / load?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 11-19-2024, 12:57 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Maybe not related but a lite weight flywheel has been known to cause misfires at idle.
Direct injection install alphasaur Engine, Exhaust, Transmission 13 06-09-2023 09:07 PM
Direct injection Rabrooks Engine, Exhaust, Transmission 3 11-01-2022 02:39 AM
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 06:17 PM
Direct injection angle solidsnake11 Software Tuning 2 02-18-2020 12:38 PM
Stock Direct Injection PSI Fenrir Engine, Exhaust, Transmission 18 05-17-2013 03:03 PM
