Drives: 2020 Subaru BRZ
Direct injection
At what rpm does the di take over. I know di and pi work together til higher rpm. But what rpm. I have a dead miss at 3k rpm and above. Drop below 3k and all is well.
Drives: brz 2017 hksv2
DI is constantly ON at all rpm and engine load, just on startup is 100% PI, then it switches to 50/50% DI/PI, then it switches again to 100% PI for a few seconds
then it switches again to 100% DI at idle and DI is then used all time at different percentage 0 means 100% DI this is for old pre restyling, newer car use a bit more port sorry but guys you need to understand that in order to help more , some kind of logs are needed said so, how you describe yes, could be something DI related |
| The Following 4 Users Say Thank You to tomm.brz For This Useful Post: |
[QUOTE=tomm.brz;3554553]DI is constantly ON at all rpm and engine load, just on startup is 100% PI, then it switches to 50/50% DI/PI, then it switches again to 100% PI for a few seconds
This helps for sure. My miss comes on at 3k rpmsthats when pi shuts off. And because i apparently have a di problem on #1 cylinder. Now i need to find the source of tbe missfire. Di injector works fine in test. Engine harrness ohms out as ok as best i can tell. Ill put it back together on Wednesday night with a different engine harness and a different injector in case my tests were not the bedt method. Thanks |
actually seeing you have 2020 car, the oem tune for your car never shuts down PI at high load like those tables i poster, but instead of 0 you have 20% PI
| Direct injection/port injection explained? | mike the snake | Software Tuning | 31 | 06-06-2021 06:17 PM |
| Direct injection angle | solidsnake11 | Software Tuning | 2 | 02-18-2020 12:38 PM |
| Direct Injection Delete Kit | Carolina Dyno | Engine, Exhaust, Bolt-Ons | 4 | 06-26-2015 11:47 AM |
| direct injection cc size | bulldog11267mad | Forced Induction | 5 | 12-03-2013 01:24 AM |
| Gasoline Direct Injection... | DoogenBurns | Engine, Exhaust, Transmission | 5 | 05-21-2012 02:05 PM |
