86 Challenge
Drives: 2017 BRZ
Upper oil pan baffle idea; is it worth trying? Ideas for improvement?
Downside is if it doesn’t work, I have to take out my engine, again. 😅 PS. With the engine stopped, the oil level is at the top of the upper oil pan and this baffle is submerged. With the engine above 5000RPM the oil level drops about 40mm exposing this baffle. Upper oil pan is ~62mm thick. |
Anti stance.
Oil already doesn’t return to the sump fast enough. This seems like it would exacerbate that.
#3 | |
Drives: 2017 BRZ PP, 2004 WRX
This is also why lower baffles don't make a huge difference and didn't really solve the gen 2 issues.
#4 | |
86 Challenge
Drives: 2017 BRZ
Partially correct; the oil doesn’t return easily from the heads and timing cover because of the convoluted return path. The crankcase doesn’t have this issue, and this baffle doesn’t affect that other than maybe a little bit for the rear left head oil return. Sent from my iPhone using Tapatalk |
Anti stance.
So only a LITTLE worse head drainage. Got it. To what benefit then?
86 Challenge
Drives: 2017 BRZ
Updates the design slightly; longer narrower louvers with more space in between to make the plate stronger. I also updated my 3D printed forming dies to be a little stronger.
86 Challenge
Drives: 2017 BRZ
And installed! Looks and feels reasonable.
86 Challenge
Drives: 2017 BRZ
I checked natural frequency to make sure nothing would vibrate at the same frequency as the engine. First in CAD, secondly by “plucking” the same corners as in CAD and measuring frequency. Everything seemed to be 614hz or higher, which is good! Less worries of vibration and fatigue. Trying to stay as far above the natural frequency of 4 piston engine at 7400RPM as possible, which is 247hz.
#9 | |
86 Challenge
Drives: 2017 BRZ
In theory, less oil and air mass spinning around the crankshaft should hopefully mean less power loss and less oil mist going out the PCV. Just a small optimization instead of the carryover part of an FB20 for less than $100 of prototyping material and some spare time as I wait for some pistons to arrive. |
| FR-S / BRZ / GT 86 - Fiberglass Subwoofer Enclosure Prototyping by Integrity Concepts | Integrity Concepts | Electronics | Audio | NAV | Infotainment | 302 | 11-16-2018 11:47 PM |
| Oil Pan Baffle | BRZFRSSTORE | Engine, Exhaust, Bolt-Ons | 0 | 04-11-2016 09:52 PM |
| Oil baffle | wootwoot | Engine, Exhaust, Transmission | 3 | 12-24-2014 09:25 PM |
| Parts Shop MAX USA prototyping | philstar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-04-2014 12:14 PM |
| Yonaka Scion FR-S Exhaust Prototyping | Yonaka | Engine, Exhaust, Transmission | 52 | 03-11-2013 05:31 PM |
