| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Subaru Brz
2013 Brz Limited Limp Mode
We scanned the car and the pending code was P0137
Checked permanent codes and it has P1235 P2096 P0087 Im assuming it could the injectors or hpfp? Anyone have experience with these codes or suggestions on what I should do first? |
The Dictater
Drives: '13 Red Scion FRS
I'd start troubleshooting with the fuel pump in the tank unless you are hearing really bad sounds in the engine bay.
How many miles are on the car? Where's the last place you stopped for gas? Any mods?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
Drives: Subaru BRZ 2017
One of three things 99% due to these codes:
Last gas you put in HFPF Fuel pump assembly (basically the regulator, fuel pump,..within the assembly..usually easier and cheaper to get used one from ebay and replaced who assembly). Easiest way of course is to test for the Fuel pressure by unplugging one of the fuel lines and plug it in to a fuel pressure gauge, turn the car to ACC Mode and wait for a minute if it's holding pressure. Good luck |
| How to Fix Limp Mode? | MidnightFumes | Issues | Warranty | Recalls / TSB | 7 | 01-20-2021 05:18 PM |
| Limp mode at 2K rpm NEED HELP!! | Arthur_frs | Engine, Exhaust, Transmission | 5 | 04-13-2020 10:22 PM |
| Limp mode | GTBOY | Issues | Warranty | Recalls / TSB | 4 | 06-07-2018 12:58 PM |
| Valet mode / limp mode? | radroach | Software Tuning | 1 | 09-18-2017 11:34 AM |
| Car in Limp mode... No CEL | Sportsguy83 | Issues | Warranty | Recalls / TSB | 60 | 08-20-2014 03:35 AM |
