Old 08-26-2024, 12:18 AM   #1
tony_n123
2013 Scion FRS Engine Issues and Codes. Rod Knock?
Hello all,
Please bear with me I am not mechanically inclined with full blown cars and I am learning as I go. About 2 weeks ago this car stalled and threw a bunch of codes.
Car is a 2013 Scion fr-s with 96K miles. Car sounds fine at idle, however when in neutral, revving to 2.0K-3.0K RPM it makes the sound in the link below:
https://streamable.com/43mcf3
Codes throw are
P0102, P0463, P0113, and P1604.
Replaced the MAF Sensor, cleaned the throttle body while I was there, replaced air intake filter, changed/bled engine coolant, new filter + oil, inspected oil for glitter but couldn't see any, replaced the battery and replaced air intake filter.
Oil used: Mobil 1 0W-20 and a K&N Filter
Reset the codes and got two new permanent codes:
P0463 and P0014
Before I throw more money at this, what else should I check? P0014 seems to be an issue with either engine oil or the oil control valve. Seems like these go out... but would a bad OCV cause that sound...? Do I have rod knock? Should I use a different oil?
Thanks for the time all.
tony_n123 is offline   Reply With Quote
The Following User Says Thank You to tony_n123 For This Useful Post:
humfrz (09-01-2024)
Old 08-26-2024, 02:09 AM   #2
tony_n123
Looks like I might need a new engine. Sounds like this video at :55
Sucks that even used, these engines are going for $4K+ on car-part near me...
Old 09-02-2024, 12:03 AM   #3
humfrz
Originally Posted by tony_n123 View Post
Hello all,
Please bear with me I am not mechanically inclined with full blown cars and I am learning as I go......................... Should I use a different oil?
Well now, tony_n123, all I know is that your car's problems have nothing to do with the oil you are using.
Before you fall off the learning curve, and your car suffers severe damage, I suggest you take it into a shop and have them evaluate it.
See how easy that can be -
2013 FR-S with electrical issues, kicking codes Lucero Scion FR-S / Toyota 86 GT86 General Forum 1 11-20-2023 12:32 AM
2013 FRS Engine Knock? Dazzo Engine, Exhaust, Transmission 5 08-23-2021 03:26 PM
2013 FRS engine for sale (rod knock) Yikes54 Engine, Exhaust, Transmission 0 04-29-2019 03:58 PM
2013 Scion frs speed sensor/codes loganmarston9696 Engine, Exhaust, Transmission 10 12-29-2018 08:43 PM
2013 Scion FR-S has a loud knock AlexT391 Engine, Exhaust, Transmission 27 02-26-2018 07:13 PM
