Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Front Brace bolt stripped
Whelp...I fudged up trying to install my Grimm speed brace. I set my trq wrench to 11! And with barley a twist and without any resistance I felt it strip. These nuts only need to be hand tighten. Also, as you can see in the pic below, between the OEM V brace thickness and Grimmspeed thickness, the nuts did not have much t grab onto.
Help! How do I fix this?? What size nut is this? m8? Also, maybe if I get a shorter nut? Anyone have an idea which nut i could go with? Also, the Grimm speed strut bar is pretty thick...I could ditch the brace entirely and just go back to OEM setup which I'm sure the nut will grab.
Drives: 2017 BRZ series.yellow
There is no way that those nuts should only be hand tightened. If that was the case, no point in the brace as it won't be doing anything.
You don't have enough threads engaging on those studs. Looks like you need longer studs (all of them), or ditch one of the braces. As for the one that's already partially stripped, maybe there is enough threads left if you ditch the aftermarket brace? |
| The Following User Says Thank You to Breezio For This Useful Post: | AJ32162 (06-13-2024) |
Yeah, I'm thinking of ditching the brace and looking for another design. There should be more threads left to grab.
Drives: Crapcan
Those brace designs are kind of crap. I have the nameless brace. It goes to the camber plate and uses conical nuts to lock it in place.
https://shop.namelessperformance.com...wrinkle-black/
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | cmiovino (06-13-2024), Ultramaroon (06-13-2024) |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (06-13-2024) |
#6 | |
not playing cards
Then I finally took a close look at where the Grimmspeed (and factory) braces are fastened. Skimpy little add-ons spot welded to the towers themselves. I won't bother, but I should go back and edit all the positive statements I made about the Grimmspeed ones.
Yeah all good learning lessons here. I'm angry with myself...Can't believe I did that, I should've known better.
Nameless design seems much better now that I know what I'm looking at.
| The Following User Says Thank You to autosenses For This Useful Post: | Ultramaroon (06-14-2024) |
#9 | |
Drives: Crapcan
#10 |
not playing cards
Hey, but you chose wisely. Those tapered nuts are brilliant.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (06-14-2024) |
#11 | |
Drives: 2017 BRZ PP, 2004 WRX
Thanks for posting this. I didn't know the Nameless bar even existed. More functional and bonus points for looks.
#12 |
Drives: Toyota GT86
If I was ever to get a strut bar it would be the Trd one. Looks great and that’s all that matters for a part like this haha.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | MrSkubi (06-14-2024), Ultramaroon (06-14-2024) |
| Header and Overpipe stripped bolt | toughguy39 | Engine, Exhaust, Transmission | 11 | 05-12-2020 03:40 PM |
| Stripped bolt head at over pipe/front pipe connection, what now? :( | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-14-2019 06:13 PM |
| Rear bolt stabilizer stripped | Trueweltall | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 07-15-2018 12:51 AM |
| Stripped Wheel Bolt | Flame9020 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 03-09-2018 10:09 PM |
| Wheel bolt stripped | 2pointSLOW86 | Issues | Warranty | Recalls / TSB | 23 | 10-13-2014 02:29 AM |
