Old 04-17-2024, 09:42 PM   #1
RaidenRacingCo
RaidenRacingCo's Avatar
Drives:
Fuel Pump Upgrade
Hey all,
My OEM fuel pump is starting to go so while the car is down, I’m taking the leap into a big boy fuel pumps for our cars. I went ahead and purchased the Radium Pump Housing Kit to have that mini-surge tank they mention about. But since I’m going with that and the other radium plumbing kit, I’m not quite sure what pump to use. I’m looking into the DW440 since it fits. The car is currently my daily (or was) and not sure if I can use the dual speed pump controller kit that I’m currently looking at. I’m just trying to future proof myself so if I need to go larger injectors, I’m not going to run out of fuel-pump. The current HP goal is 200ish NA. We’re pretty close to that on the current tune (185 whp). Probably won’t gain much but a boy can hope. With that said, can I run the DW440 on a stock harness loom and control it via ECUtek? (Probably a question for my tuner but he’s on vacation until May and I don’t wanna bother him).
RaidenRacingCo is offline   Reply With Quote
Old 04-18-2024, 12:29 PM   #2
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
If your goal is 200 whp, there is zero reason to upgrade (capable of 300-350 on stock fuel pump), and you are only then moving from a highly reliable factory fuel pump to a less reliable aftermarket unit. No benefits, only downside.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
The Following 4 Users Say Thank You to terboboost For This Useful Post:
DarkPira7e (04-18-2024), RedReplicant (04-18-2024), Spuds (04-18-2024), ZC6_STi (04-18-2024)
Old 04-18-2024, 08:11 PM   #3
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
I agree with terboboost. Even tuners would say, to stick with the OEM fuel pump. You're just pouring money that isn't necessary if you're not putting down 350+whp. OEM fuel pump costs between $80-$180 whether it's used/new. If your goal is just 200whp, stick with the OEM Pump, and no need to upgrade any of the fuel systems.
UEL/EL header, FP, Catback, and E85 are enough to get close to 200WHP on an ECUTek tune.
ZC6_STi is offline   Reply With Quote
What Power Level for Upgraded Fuel Pump - Pump Gas DarkPira7e Engine, Exhaust, Transmission 10 08-02-2020 10:07 AM
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
Fuel pump upgrade install help Dream20b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-23-2016 07:20 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
