Old 04-12-2024, 02:32 PM   #1
AsherTM
Drives:
Transmission noise
I’ve currently got a 2015 scion frs and it’s been making some noises i’ve never heard before. the noise sounds like it’s coming from just behind the engine, it does not sound like a bearing because it is making a squeeling noise rather than a grinding noise. it seems to stop when i push down on my clutch, as well after the vehicle is running for a while. would anyone know what the problem would be i’ve looked everywhere on the internet and cannot find a sound that is remotely close to what mine sounds like.
AsherTM is offline   Reply With Quote
Old 04-12-2024, 03:11 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe you should Google "noise stops push down clutch pedal".
I've never heard a bearing make a "grinding" noise
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 04-12-2024, 05:31 PM   #3
AsherTM
Drives:
yeah I’ve been looking at my engine bay for a bit and i think i’ve come to the conclusion that’s it’s either my throw out bearing, or my slave cylinder needs to be greased. when i push down on my slave cylinder the noise stops and only makes noise when idling
Old 04-12-2024, 06:26 PM   #4
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Do you have a stock or aftermarket clutch? Usually, if it's a Stage 2 or 3 makes some noises when idling that aren't related to the TOB or slave cylinder.
ZC6_STi is offline   Reply With Quote
Old 04-12-2024, 06:51 PM   #5
AsherTM
Drives:
No. I have a stock clutch that’s why i’m thinking it’s just the slave cylinder and needs to be greased
Old 04-12-2024, 11:41 PM   #6
ZC6_STi
ZC6_STi's Avatar
If it is like a creaky noise (not a grinding noise) when you step in and out of the clutch whether the engine is off or on, then it the "slave cylinder" needs to be lubricated as well as the pivot fork where it meets the clutch fork underneath the dust boot from the transmission. I would suggest lubricating both to reduce the noise. If neither resolves the problem after the lubrication, it's a TOB or clutch-related issue. Some other ideas are how many miles did you have the stock clutch for? Was it replaced or not? Otherwise, some videos would help the members to pinpoint the issue.
what can this noise be? transmission? Angel237 Engine, Exhaust, Transmission 6 06-24-2021 07:08 PM
Transmission noise WoodyDeuce Issues | Warranty | Recalls / TSB 7 06-10-2021 01:10 PM
Transmission noise Harjotdhanota Engine, Exhaust, Transmission 2 12-03-2017 02:42 AM
Transmission noise MyGT86Yas Engine, Exhaust, Transmission 42 11-04-2017 03:30 PM
Transmission Grinding Noise RedFR-s Issues | Warranty | Recalls / TSB 18 07-06-2016 02:18 PM
