Old 04-06-2024, 10:06 AM   #1
ROADRACER
Drives: unlimited cheap build N/A track car
2013 direct replacement
I just destroyed my engine after a long 5th gear pull. I felt it tightening up at about 120 mph and lifted. Soon after a horrible rod knock. I'm sure when I look the oil pickup screen will be full of gasket sealant. The engine was perfect with 75k miles...anyway, I will probably try and get a used engine for an easy swap. What years are plug and play. 2013-2016? thanks
ROADRACER is offline   Reply With Quote
Old 04-07-2024, 07:18 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Yes 13-16, with exception of the coil packs. Shouldn't really matter since you can just use whatever coil pack matches the harness that comes with the engine (or the harness you swap over).
Auto versus Manual engine also has differences, but they can easily be accommodated. Easier if you're going from AT->MT. A little more work if you're going MT->AT
EndlessAzure is offline   Reply With Quote
Old 08-20-2024, 10:38 AM   #3
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
2013-2016 are compatible. Use the engine harness and temp sensors off your broken engine. Engines are MT/AT specific and need additional work if you want to intermingle (Install an AT block in a MT and vice-versa)
Interested in why you think the pick up would be plugged with RTV? Has the engine been apart previously?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Ultramaroon (08-20-2024)
Direct Injectors stuck replacement tool? brandonblt2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-28-2022 04:38 PM
Has anyone tried the Powerbass OE direct replacement speakers? soilent Electronics | Audio | NAV | Infotainment 8 04-08-2022 04:16 AM
What are some direct fit replacement options for OEM FRS spoiler? FewTooManyBeers Cosmetic Modification (Interior/Exterior/Lighting) 11 07-22-2018 09:09 PM
FS: Direct Replacement Steering Wheels 86_ZN6 Interior Parts (Incl. Lighting) 5 11-01-2013 05:26 AM
Is there a Direct Fit Map Sensor replacement sw20kosh Forced Induction 10 07-04-2013 09:21 AM
