Old 04-01-2024, 04:54 PM   #1
17Brz.Zah
Drives:
Ratting after installing Tomei UEL
Hey all, I apologize if this isn't the proper place but I was hoping for some ideas. I recently installed Tomei Uel headers on my 2017 brz with 140,000kms
During the second drive, after reinstalling the skid plate I can hear this vibration/tin like noise from the front right side of the car. It's very obvious when getting past 4k rpm.
Most obvious in video after 3rd rev)
Just as a short list of what I have tried, I checked for contact along the skid plate itself, there was two small points of contact but I have since corrected them.
I retorqued all the bolts connecting the header to the block and overpipe.
Felt around the over pipe and its not contacting the sub frame
Any help is much appreciated
17Brz.Zah is offline   Reply With Quote
Old 04-01-2024, 08:23 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you drive it with out the skidplate?
Old 04-01-2024, 08:28 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Check for exhaust leaks?
EndlessAzure is offline   Reply With Quote
Old 04-01-2024, 09:23 PM   #4
17Brz.Zah
Drives:
A short drive around the local neighbourhood, around 5 minutes.
Got under it tonight after and found that the heat shield mount closest to the header had very neatly cracked and was creating the racket.
Old 04-01-2024, 09:25 PM   #5
17Brz.Zah
Drives:
Updated
Yes I did, no soot or anything around or on the new gaskets.
Could probably clog the exhaust and shoot compressed air into it with some soapy water but for now I don’t think it’s necessary.
TOMEI now in stock @OAKOS! We are an offical TOMEI stocking Vendor! OAKOS Automotive Engine, Exhaust, Bolt-Ons 313 03-11-2020 10:35 AM
FRS – Tomei UEL, Tomei Overpipe, Stock Front Pipe, Manzo V2 exhaust Timmy_Jones Engine, Exhaust, Transmission 0 05-01-2017 10:29 AM
Trouble installing Tomei 60s catback Kestrel Engine, Exhaust, Transmission 6 10-14-2016 10:07 PM
Trouble installing Tomei 60s catback Kestrel Engine, Exhaust, Transmission 1 10-13-2016 12:33 PM
Ratting when slowing down aghuman Issues | Warranty | Recalls / TSB 9 03-23-2014 03:08 AM
