Old 03-08-2024, 04:24 PM   #1
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
GKTech 5x114 conversion
GKTech has finally released a solution to 5x114 conversions on the 86.
https://us.gktech.com/products/fr-s-...onversion-hubs
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
The Following User Says Thank You to Falkon240 For This Useful Post:
Teseo (03-09-2024)
Old 03-08-2024, 09:28 PM   #2
RedReplicant
Drives: None
After my experience with some of the other GKTech stuff I will let someone else be the guinea pig, either way curious how these hold up on heavily beaten track cars.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
villainous_frx (03-11-2024)
Old 03-15-2024, 12:21 AM   #3
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I'll be the pig. The kit just arrived at my house.
IG
2013 Scion FR-S
RedReplicant (03-15-2024)
Old 05-17-2024, 05:30 AM   #4
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I didn't get around to updating this because every time I tried, the site was down :|
The installation is pretty straightforward. My first and most helpful tip is to uninstall all 4 ABS sensors from each corner. I didn't do that and damaged some sensors causing ABS warning lights and the car was stuck in limp mode until I went around and replaced all 4 butchered sensors.
Removing the axles from the rear hubs was easy because I had my broken axles swapped when my subframe bushings and diff raisers were installed.
One thing that you want to beware of is if you keep stock front brakes while using the DBA brake rotor, the hat is slightly larger than stock. You MUST shave the front bracket about 7mm to clear the rotor hat. To avoid this, I got rid of the stock brakes altogether and installed 4 pot calipers off of a TRD model FR-S.
The front swap was way easy.
I recommend getting the front rotors (DBA42663S-10) from GKTech while they still offer 20% off on the parts. Get the matching rear rotors from Ken at KNSbrakes. I got the blank rear rotors (KNS4651)because I wanted to save 30 bucks or something stupid and now I regret it
Also, a big surprise for me, I made it onto one of the GKtech promo emails.
IG
2013 Scion FR-S
Wally86 (05-22-2024)
Pbm 5x114.3 conversion gui dube987 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 11-15-2018 03:26 PM
5x114.3 Hub Conversion moomoopanda Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-07-2015 06:28 AM
5x114.3 Hub Conversion PhoKingCool Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 12-28-2014 07:05 PM
5x114 hub conversion FRSGIRL❤ Brakes, Suspension, Chassis 1 07-06-2013 02:24 PM
5x114.3 hub conversion mclevin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-03-2012 09:53 AM
