Old 02-28-2024, 09:30 AM   #1
jbug187
Drives: 2022 Subaru BRZ Limited MT
Do I Need Extended Wheel Studs?
During my last track day, a fellow twin driver (he was on GR86 and I have a BRZ) mentioned that I really needed to install extended wheel studs. I didn't think that was correct, but wanted to check with the community in case I'm mistaken. Details below. Any advice is appreciated. Thanks.
Winter Configuration
  • Wheels: Stock
  • Spacers: KSP
  • Thoughts: Since the KSP spacers have their own studs built in, I don't need to extend the studs built into the rotor. In fact, if the studs built in to the rotor were extended, I don't think I'd be able to mount the KSP spacers at all?
Summer Configuration
  • Wheels: Aodhan AH09
  • Spacers: None
  • Thoughts: Since these wheels mount directly to the rotor without any spacers I should be fine with the regular studs?
jbug187 is offline   Reply With Quote
Old 02-28-2024, 10:35 AM   #2
foshjowler
Drives: 2022 BRZ; 2014 BRZ
Extended studs aren't needed for either of those situations. The only thought I'd have is that the stock studs aren't known for being great, so a higher quality stud wouldn't be a terrible idea if you're swapping wheels a lot.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 02-28-2024, 10:00 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You only need extended studs if you run slip-on spacers
EndlessAzure is offline   Reply With Quote
Old 02-29-2024, 03:40 PM   #4
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
While extended studs might not be needed, I have found longer lug nuts do wonders for making the wheels easier to swap.
I swap my wheels pretty frequently and went with some aftermarket spline-driven nuts. They are longer and much easier to use than the short, stubby OEM ones. I went with some with closed ends for peace of mind.
Desertnate is offline   Reply With Quote
Old 03-01-2024, 03:09 PM   #5
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
as others have said, longer studs aren't necessary, but if you plan to track the car and frequently swap/ rotate wheels, then stronger studs would be a great idea. The ARP studs for these cars are also longer, but that's not the main intent.
I know lots of people have had issues with the OE studs, so it wouldn't hurt. but it's not something I would prioritize over seat time or good brake pads, fluid, etc if you're playing within a limited budget. but it is a top-10 on the good practices..
.... FWIW, I've used ARP studs on all my race cars and have swapped wheels hundreds of times with air tools/electric impacts every time. I have damaged ONE ARP stud in that time because I cross-threaded a lugnut going on one time. otherwise, >20 yrs of HPDE and racing and I've never had a failed wheel stud. it's an investment you only need to make once.
Matt93SE is offline   Reply With Quote
Extended Wheel Studs? ModalSoul37 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-07-2018 04:55 PM
Wheel Lockers for Extended Studs? MisterSheep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-02-2016 10:48 AM
ARP Extended Wheel Studs FrSnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-17-2014 11:51 AM
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 01:00 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
