Old 02-08-2024, 05:04 PM   #1
raz.sofer
raz.sofer's Avatar
Drives: Subaru BRZ 2015
Power steering going bad?
Hi.
I have a 2015 BRZ with quite a lot of kilometers on it (187K)
In the last two weeks I have encountered an issue with the power steering “disconnecting”, going back to work after restarting the car, and can come back after 5 minutes or can be gone for days.
I have got an error code C1528 but couldn’t find a lot of information about it. From my understanding, a recalibration of the steering sensor is needed, but upon looking at the log on the ECUTEK app, it seems pretty accurate.
Did anyone encounter such issue and found a solution?
I would imagine that if the sensor is bad, it would be always bad, not just weirdly coming on and off.
raz.sofer is offline   Reply With Quote
Old 02-08-2024, 07:28 PM   #2
SuperSub7
Drives: Awesome
Error code C1528 usually means a problem with the steering angle sensor calibration or signal. Also, you can try to check for any loose or damaged wiring, connectors, or components within the power steering system, including the steering angle sensor and its connections.
SuperSub7 is offline   Reply With Quote
power steering codes denverroat BRZ First-Gen (2012+) — General Topics 3 06-30-2023 11:47 AM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 05:27 PM
Power Steering rosol16 Issues | Warranty | Recalls / TSB 15 12-15-2015 09:44 AM
Where is our power steering ECU? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-24-2015 12:38 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
