Old 02-01-2024, 06:41 PM   #1
Shellsh0ck
Drives: Black frs
HVAC electronic issue
Recently my AC controls started acting up.
Manual AC on a 2013 FRS
If i turn the fan to the 1… AC is still off.
2-3-4 speed turns the AC on. But the fan intensity doesnt change
Its turned into an on and off switch with 0 & 1 being off, and 2,3,4 being on.
Any ideas?
Shellsh0ck is offline   Reply With Quote
Old 02-01-2024, 07:04 PM   #2
SuperSub7
Drives: Awesome
Your AC control issue in the 2013 FRS could be caused by a faulty blower motor resistor. It controls fan speeds, and if it's failing, it may not work correctly at lower speeds (1st). You should check out the blower motor resistor.
SuperSub7 is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperSub7 For This Useful Post:
22R (02-02-2024), pope (02-10-2024)
Old 02-01-2024, 08:13 PM   #3
Shellsh0ck
Drives: Black frs
I just took the resistor out and checked it. Its not at the correct specs but doesnt seem to be so far out as to make the AC act as it does. To clarify the AC is still -off- when switching to 1 on the fan. Not low. The AC light on the heater control doesnt turn on until I switch the fan to 2.
Heres what I measured at the resistor connections vs what its supposed to be IAW the manual:
Ohms b/w 1-4: 3.5 measured (2.92 per manual)
Ohms b/w 1-3: 1.1 measured (0.44 per manual)
Ohms b/w 1-2: 1.8 measured (1.12 per manual)
Would this difference in resistors cause this issue?
Also when I turn the car on (with the fan in 4) you can hear it (assuming the blower?) click, whirr on then stop. It doesnt come on again as you change settings until you turn the car off and on again. It does blow air tho… at the selected temperature, just not at any increased intensity on fan speeds 2,3&4
Old 02-06-2024, 07:33 PM   #4
SuperSub7
Drives: Awesome
While these differences aren't extreme, they can affect the performance of the blower motor and the behavior of your HVAC system. Also, each resistor coil corresponds to a different fan speed setting. When the resistance values don't match the expected values, it can lead to inconsistent fan speed operation. This is why your blower motor isn't coming on at higher speeds (2, 3, and 4) until you turn the car off and on again. I think when it comes to the "click, whirr on, then stop" sound you hear when you turn the car on suggests that the blower motor might be receiving power but then encountering a problem that shuts it off and it could possibly be the resistor values. Replacing the blower motor resistor with one that matches the specified values in the manual might be a reasonable step to take.
Old 02-14-2024, 09:58 PM   #5
Shellsh0ck
Drives: Black frs
Well i went ahead and replaced the resistor and its still doing the same thing. So whats next?
air, blower, conditioning, hvac
My HVAC - hot, cold, and not much else . . . geezerbrzeezer Electronics | Audio | NAV | Infotainment 22 03-02-2017 02:03 PM
HVAC Twist LED? xFury Cosmetic Modification (Interior/Exterior/Lighting) 2 03-09-2016 05:49 PM
BRZ HVAC Lorico Interior Parts (Incl. Lighting) 0 08-22-2015 12:01 AM
HVAC Options? 86KEEBS Cosmetic Modification (Interior/Exterior/Lighting) 9 01-27-2013 09:55 PM
Electronic Throttle Issue FRiSson Issues | Warranty | Recalls / TSB 0 09-28-2012 10:35 AM
