Old 01-02-2024, 07:33 PM   #1
Theodorable
Drives: 2015 Scion Frs
No Power?
So I was driving my car perfectly fine and I decided I wanted to move my car into the garage. electronics still worked at this point. Locks, gauge cluster worked. Right when I went to turn the car over it clicked once and completely died. I checked all the fuses they're good except the DRL and fog light fuse which shouldn't hinder the car from starting. replaced the battery today thinking it would fix it since the last one was bad told to me by AAA and AutoZone. Also when I plugged the battery in when it was good and running. You'd hear electronics turning on and the fuel pump and things of that nature being activated. But now with the battery before I replaced it, nothing seems to be activated as well with the new battery I just installed as well. the wipers work and the led for the ac is on but nothing in the gauge cluster is on. I don't know what it could be. the car makes 3 clicks when I turn the key over but that's about it. the battery fuses on the terminal are still good LMK your inputs thank you.
Theodorable is offline   Reply With Quote
Old 01-02-2024, 08:25 PM   #2
This is similar to what happened with mine when the battery tie down came loose and the vehicle shorted out over a bump.
I know you said you checked the fuses, but make sure you checked the main fuse for the starting system, engine control unit (bottom right fuse in the engine fuse box). I believe that is the one that popped in mine.
Old 01-02-2024, 09:30 PM   #3
Theodorable
Noted I will double check everything and update you
Old 01-03-2024, 11:42 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
The ability to check fuses is not a substitute for the possession of and knowledge of how to use a multi-meter. If you don't have one, purchase a cheap one from your local auto supply store and learn how to use it, then come back and we can ask more specific questions that you can verify for us.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-03-2024, 04:16 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is this your AT>MT project car?
Old 01-03-2024, 05:38 PM   #6
Theodorable
Yeah but this is a different issue has nothing to do with manual swapping…
Old 01-03-2024, 07:59 PM   #7
Ultramaroon
not playing cards
So you got it running?
Old 01-04-2024, 12:53 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You sure about that? There are a few grounds that mount to the top of the block by the bell housing. You get them all back in place? I think there is a ground on the long starter bolt too. Can’t remember for sure.
Old 01-04-2024, 12:57 AM   #9
Theodorable
Idk if you read my post or not you’d see
Old 01-04-2024, 12:59 AM   #10
Theodorable
Ofc I’m sure. How else would I be driving the car if I didn’t plug everything back in and into place? It was literally running and I was driving it.
Old 01-04-2024, 01:04 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My other car wouldn’t start the other day. Neg terminal was loose. Bad connections do inconsistent things.
Old 01-07-2024, 02:29 AM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Electricity is a bitch.
Old 01-12-2024, 01:54 AM   #13
Ultramaroon
not playing cards
Any news?
Old 01-13-2024, 04:20 AM   #14
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Any news?
https://www.abc.net.au/news
Dead battery - OBD-II power and cigarette lighter power? lapsio BRZ First-Gen (2012+) — General Topics 10 04-08-2021 08:22 AM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
More power with Agency Power vividracing Engine, Exhaust, Bolt-Ons 0 07-26-2013 04:27 PM
