Winter ***e engaged
Drives: Ashpalt 2014 Frs Manual
Propane smell
Hey folks. I have a 2014 frs
I've got an unrulling rotten egg / propane smell once the car is warm I've been battling this a while. The first thing I did was change the cat. I went with an lachute high flow cat. I've since retuned the car. The car had its engine built a few years ago, eagle rods, ACL bearings Apr head bolts stock compression and crank.. baffled pan, greedy pick up. Full exhaust. The engine leaks a lot. The engine builder hasn't been helpful and hasn't fixed it. I plan to pull in the spring and fix the leaks. Before the smell started I changed a coil pack, ( no 1 ), I had a track day and used an octane booster and later used a fuel system cleaner. It was fine during that period. After a few weeks following these events the smell started. My first action was changing the cat. Still no luck. Would anyone have any ideas? Car runs well, tune looks good. No cel codes. Battery isn't leaking..
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
Cabin air filter?
Sent from my KB2007 using Tapatalk |
Drives: 17 Asphalt 86
The smell is on the outside. I Can confirm the air around the car does indeed reek of a propane like scent.
Winter ***e engaged
Even changed the filters, it's outside mostly
#5 | ||
Wheels for Brains
The only thing on the car I think smells like this is gear oil. Gear oil contains sulfur compounds, which is notorious for bad egg smell. Check your transmission and differential. Likely:
| The Following 2 Users Say Thank You to EndlessAzure For This Useful Post: | Ft86Chris (12-12-2023), Ultramaroon (12-12-2023) |
#6 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Not just the bolded part. But emphasis on the bolded part. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Ultramaroon (12-12-2023) |
Winter ***e engaged
Solved!
Bad gear oil in the diff. Thanks everyone
| The Following 3 Users Say Thank You to Ft86Chris For This Useful Post: |
| Smell Gas? | Skurj | Issues | Warranty | Recalls / TSB | 14 | 05-25-2020 11:05 AM |
| New Car Smell | Frisco | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 35 | 02-28-2018 06:09 PM |
| Gas smell | S84kam | Issues | Warranty | Recalls / TSB | 6 | 02-14-2016 02:11 AM |
| Odd smell | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 11 | 01-18-2015 01:49 AM |
