Old 12-11-2023, 09:59 PM   #1
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Drives: Ashpalt 2014 Frs Manual
Propane smell
Hey folks. I have a 2014 frs
I've got an unrulling rotten egg / propane smell once the car is warm
I've been battling this a while. The first thing I did was change the cat. I went with an lachute high flow cat.
I've since retuned the car.
The car had its engine built a few years ago, eagle rods, ACL bearings Apr head bolts stock compression and crank.. baffled pan, greedy pick up.
Full exhaust.
The engine leaks a lot. The engine builder hasn't been helpful and hasn't fixed it. I plan to pull in the spring and fix the leaks.
Before the smell started I changed a coil pack, ( no 1 ), I had a track day and used an octane booster and later used a fuel system cleaner. It was fine during that period.
After a few weeks following these events the smell started. My first action was changing the cat. Still no luck. Would anyone have any ideas? Car runs well, tune looks good. No cel codes. Battery isn't leaking..
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
Ft86Chris is offline   Reply With Quote
Old 12-11-2023, 10:01 PM   #2
Ashikabi
Ashikabi's Avatar
Cabin air filter?
Sent from my KB2007 using Tapatalk
Old 12-11-2023, 10:09 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The smell is on the outside. I Can confirm the air around the car does indeed reek of a propane like scent.
Old 12-11-2023, 10:20 PM   #4
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Cabin air filter?
Even changed the filters, it's outside mostly
Old 12-12-2023, 01:14 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Full exhaust.
The only thing on the car I think smells like this is gear oil. Gear oil contains sulfur compounds, which is notorious for bad egg smell.
Check your transmission and differential. Likely:
  1. The transmission rear seal (where the driveshaft connects)
  2. Blow-over from the transmission vent hole (near the top of the case)
  3. Axle shaft seals (differential casing sides)
However there are other possible joints, so look around the whole transmission and differential casing to see if it's wet with gear oil anywhere. If you see any sheen, dab some up with your finger and smell it. It's not a smell you can mistake
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
Ft86Chris (12-12-2023), Ultramaroon (12-12-2023)
Old 12-12-2023, 03:37 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
^ That
Not just the bolded part. But emphasis on the bolded part.
The Following User Says Thank You to x808drifter For This Useful Post:
Old 12-21-2023, 07:01 PM   #7
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Solved!
Bad gear oil in the diff. Thanks everyone
The Following 3 Users Say Thank You to Ft86Chris For This Useful Post:
Ultramaroon (12-23-2023), Wally86 (12-22-2023), x808drifter (12-22-2023)
Smell Gas? Skurj Issues | Warranty | Recalls / TSB 14 05-25-2020 11:05 AM
New Car Smell Frisco Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 35 02-28-2018 06:09 PM
Gas smell S84kam Issues | Warranty | Recalls / TSB 6 02-14-2016 02:11 AM
Odd smell FloridaBRZ BRZ First-Gen (2012+) — General Topics 11 01-18-2015 01:49 AM
