Old 12-09-2023, 07:36 PM   #1
subiesenior
subiesenior's Avatar
nelp help bent rear trail control arm mounts
I was in the rain with marginal tires, spun the rear around and the L rear hit the curb, I have spec adjustable trail and lower control arms which held up but the mount on the body bent
subiesenior is offline   Reply With Quote
Old 12-09-2023, 09:37 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Subframe is replaceable. Need to check to see if the mounting points are tweaked though, there are 4 main mounting bolts that hold the subframe to the body. There are also subframe braces up front, if those are not warped I would probably assume the subframe took the brunt of the impact.
Old 12-10-2023, 01:00 AM   #3
norcalpb
norcalpb's Avatar
I would take @NoHaveMSG advice and see if anything else was damaged in the hit.
As an alternative to replacing the subframe (if everything checks out), you can order these:
https://www.86worx.com/gp-sports-rea...lars-1285.html
These will completely replace your destroyed trailing arm pickup points.
Old 12-10-2023, 02:32 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That would be way easier than dropping the subframe. What a PITA that is.
Old 12-18-2023, 08:16 PM   #5
subiesenior
yeah that is something I didn't consider so I checked and I can get a used subframe for liek $200 and just replace it. Thanks now I have to get it on the lift it's sitting about about 5 ft away
Rear lower control arms, motor mounts Summerwolf Brakes, Suspension, Chassis 2 10-07-2020 08:55 PM
Bent front control arm, options? Dkfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-13-2020 01:05 PM
FS: RCE Tarmac 2 Clubsport coilovers, Ground Control Camber Plates/rear mounts gatorac Brakes, Suspension, Chassis 5 08-25-2015 01:31 PM
Testing Waters: FS KWV3s with Ground control camber plates and robispec rear mounts YDNA Brakes, Suspension, Chassis 0 01-25-2014 02:34 AM
Bent lower control arm Notso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-13-2014 08:52 PM
